A body big block headers.. What do you guys run?
#1407066
03/23/13 12:43 PM
03/23/13 12:43 PM
Posts: 572 Portland , Oregon, United Stat...
smokes
I am going a 440 in my 71 duster and want to run headers in my car. I will be running power steering and a mini starter. What do you guys recommend for exhaust headers? I love the look of the TTI headers but cannot spend that much on headers as I am building the car on a budget. I was thinking of headman headers as I have used them before..
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
Re: A body big block headers.. What do you guys run?
[Re: Dcuda69]
#1407068
03/23/13 01:46 PM
03/23/13 01:46 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Im planning on using TTI on my 440 dart. I have them on my wife's Hemi in her 65 Coronet. They went in great and clear everything, and that's with PS. No offense to anyone But Its hard to believe anyone bought the CPPA design, It heard they are a Nightmare. Poor plug and wire clearances etc...
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: smokes]
#1407070
03/23/13 04:48 PM
03/23/13 04:48 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
What is the projected HP of this budget build ?
[Re: smokes]
#1407071
03/23/13 05:03 PM
03/23/13 05:03 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My 71 Demon was a race only car,butI'm going to have it also do street duty.I had 2" Pro Parts headers on it,but went with Scumacher Tri-Y headers.Plenty of header to run 11's.
[Re: BB65Barracuda]
#1407075
03/23/13 09:25 PM
03/23/13 09:25 PM
Posts: 4,945 WI
Dcuda69
WI
No offense taken. I put this car together(the 1st time)back in the mid-nineties...there were not a lot of choices then. I had to clearance them in a few spots and finesse some tubes for ground clearance but all in all they work. The only problem I didn't have was plug wire fit. I've had them on iron heads as well as the Eddy heads I'm running now...same wires.They are,however, a custom made set I put together myself using Taylor wire
[Re: Dcuda69]
#1407076
03/23/13 09:49 PM
03/23/13 09:49 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Id still can only recommend the TTI units. Taking a lot of time laying on your back to change plugs is not my idea of a good time. Taking headers in and out of a BB A Body car several times to tinker is way more than I personally would care to deal with. Im getting to old for that. The TTI units are pricey but they are worth all the stress and hassle they will save you in the long run. Just My My 440 Dart had a set of "persuaded" headers on it when I bought it. If you want a Budget set that is a PITA to work with.
[Re: Dcuda69]
#1407080
03/24/13 01:08 AM
03/24/13 01:08 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: smokes]
#1407083
03/24/13 06:31 PM
03/24/13 06:31 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Sounds like a plan, Buy a used set of BB Header out of the forum here. I think there is a set or two in the race parts section.
