Re: Mopar Quadrajet ??
[Re: ChinooK440]
#1406269
03/22/13 11:07 AM
03/22/13 11:07 AM
Posts: 15,487 Florida
scratchnfotraction
I think what your calling an electric vent MIGHT be a mixture control solenoid which would be an electronic feedback carb. that needs a computer and associated sensors etc. to run correctly.
it may have the mettering needles that get a pulse/noid for the idle mixture.
IMHO,I would grind the shaft and remove the mopar throttle lever,find a older chebby carb from a 327/350, weld the mopar throttle lever onto the chebby carb throttle shaft.
this way all of the mopar throttle linkage/TV linkage hooks up correctly.
I am running a 1974 chebby q-jet on my roller cam 318 in the 85 truck.
hugh jorgan sent me a newish 1905 edelbrock q-jet/thermobog replacment carb for 72-85 dodge truck with 360/400/440(they dont make them any more) which is awsome with a working elect choke.
it shows a mopar throttle adaptor in the owner manual for it,but the lever looks almost identical to the mopar lever I use.
I just put the stock throttle stud in and it all adjusted out great with the stock throttle bracket/1-piece rod TV linkage for the mid 80s trucks.
do you have the intake bracket with correct rod/trans lever?(I have 2 set ups if you need one)
I have a few q-jets that I grabed up for future mods to fit mopar.
[Re: ChinooK440]
#1406270
03/22/13 05:14 PM
03/22/13 05:14 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
with this and Scratchin'. If that truly came off a 5th it wasn't the original carb, OEM was T-quad until '87 I think, then was feedback Qjet with spark and fueling computer (often mis-named as Leanburn).
Either way, I don't think 5ths ever got a 4-v, I think later ones of the feedback era got electronic Holley 2-barrels.
So, figure out for sure what you have and what that solenoid is. If it's a GM carb it could be from teh early 80s and with a solenoid bowl vent or something.
[Re: dogdays]
#1406272
03/22/13 07:47 PM
03/22/13 07:47 PM
Posts: 680 NW IL
Biggie
NW IL
Here is a internet pic of the carb we have. We need to know what the blue plug in goes to
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon 03 chrysler 300m 10 dodge charger
[Re: Biggie]
#1406273
03/22/13 09:03 PM
03/22/13 09:03 PM
scratchnfotraction
IIRC that blue plug is the noid for pulsing the metering needles. IIRC I have a carb in the shed that is apart. i will go take a pic of the inside of one. dog,the edelbrock 1905 were new casting to start with.it works like no other q-jet I have had. the choke works,its not worn out, and it was FREE!! wow! what a kick it has on the 440 over the 600 eddy carb.
[Re: scratchnfotraction]
#1406274
03/22/13 09:06 PM
03/22/13 09:06 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
..... in the shed that is ....
I have read many, many references to this " shed ". I'll bet it is huge!
[Re: Hugh Jorgan]
#1406278
03/23/13 04:20 AM
03/23/13 04:20 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
The truck Mopar Qjets don't have all that crap on them. I pulled one from a 86 van. My van engine came with a 87 Qjet.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
#1406280
03/23/13 08:34 PM
03/23/13 08:34 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
here is the new replacement shed. 12x20
That's the shed on the left, right? Has to be to be big enough to hold all your goodies.
[Re: poorboy]
#1406285
03/27/13 11:42 AM
03/27/13 11:42 AM
Rug_Trucker
A whistle maybe the throttle shaft. When the shaft gets sloppy, the butterflies hang up onthese carbs.
