Dim headlights on high beam #1406044
03/21/13 12:27 PM
03/21/13 12:27 PM
Owosso, Michigan
stateroadhog Offline OP
Owosso, Michigan
I did the madd conversion to relays for my headlights on my 70RR. Which is adding relays to send direct current to headlights. When I turn the high beams on the low/high beam outside lights get dim. Any thoughts. Grounds are good.
Re: Dim headlights on high beam [Re: stateroadhog] #1406045
03/21/13 12:31 PM
03/21/13 12:31 PM
If the lights are 100% functioning (jump 12V directly to the lights to answer that Q) & the ground side is all good then that only leaves the hot side & I'd check the voltage drops from batt (or alt) to relay to lights to ID the poor connection
