A Little Help Needed... #1406022
03/21/13 09:18 AM
03/21/13 09:18 AM
70RT Offline OP
70RT  Offline OP
Stock BB E-body with factory exhaust manifolds. Any body have a proven way to remove the driver's side rear manifold sleeve nut w/o dropping the steering column/shaft? Tried every extension, wobble, universal combo I had yesterday and can't get it out. Appreciate any suggestions that might work w/o messing with the column.
Re: A Little Help Needed... [Re: 70RT] #1406023
03/21/13 04:32 PM
03/21/13 04:32 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Have you tried taking the nut off the driver's side motor mount (the one that goes through the K-Frame) and jacking the engine up?
