Re: Shorty TTI's
[Re: 67autocross]
#1405778
03/21/13 12:52 AM
03/21/13 12:52 AM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Too bad they won't fit my Aussie Charger.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Shorty TTI's
[Re: 67autocross]
#1405782
03/21/13 01:34 AM
03/21/13 01:34 AM
amxautox
Ya, it's up to 50 degrees now. Was 60 for a day or two.
Tom
author unknown
Re: Shorty TTI's
[Re: amxautox]
#1405783
03/21/13 01:37 AM
03/21/13 01:37 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
It was -24C in Winnipeg this morning....no problem with the heat here.
A new iron curtain drawn across the 49th parallel
Re: Shorty TTI's
[Re: Kern Dog]
#1405786
03/21/13 09:23 AM
03/21/13 09:23 AM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Yes, they do have some high prices, but if you looked around, they are the best ones for mopars around. Add to that they probably have to build sets to order and based locally, they probably are just making enough to keep in business. I would be very tempted the pull the trigger, but wonder if those would clear fast ratio pitman arms? I've noticed other similar quality headers around and their peices are like $400-$500. At least TTI offers diffrent coatings.
Re: Shorty TTI's
[Re: amxautox]
#1405788
03/21/13 11:19 PM
03/21/13 11:19 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
maybe not. but it looks like there are options if you order from down under. for example extractors for valiant v-8 IMO these are better looking design than the small block tri-y sold by Schum___r But of course the odds of fitting a US A-body without modification is not so good so I took a pass on ordering them...
Re: Shorty TTI's
[Re: amxautox]
#1405790
03/22/13 12:14 AM
03/22/13 12:14 AM
Mattax
Phila. Pa.
If and when you do get them, it would be great if you could eyeball the up with a US car to see if they might work. In the meantime I'm going to try these shorties. I've had to face the reality I don't have the time or space to do up custom headers. This ought to be a significant improvement for my setup. The one test I'm familiar with was done by Mopar Muscle on 360 with hp peak at 4500 Crate Motor Exhaust Test Even that engine had torque improvement as well as hp gain with the Hedman shorties. A higher reving engine, or higher flowing port situation should benefit more. My engine's hp peak is closer to 5500 rpm and could use a bit of help lower in the range too.
Re: Shorty TTI's
[Re: Mattax]
#1405791
03/22/13 12:16 AM
03/22/13 12:16 AM
amxautox
The main problem with U.S. and Aussie headers/extractors fitting each other's cars is the steering box. I doubt they would interchange.
Tom
author unknown
Re: Shorty TTI's
[Re: amxautox]
#1405793
03/22/13 12:22 AM
03/22/13 12:22 AM
Mattax
Phila. Pa.
Re: steering box might be in the way That's was my thinking too. Are the chassis's pretty similar? Maybe a more useful part for those with right hand drive Barracudas in the UK.
Re: Center dump shorties Like the Hedmans? I think you'll have to modify them. At that point, is it worth it over doing a custom? Easier maybe if you're doing it all yourself.
Re: Shorty TTI's
[Re: Mattax]
#1405794
03/22/13 12:30 AM
03/22/13 12:30 AM
amxautox
They seem to be a little similar. The Aussie Charger uses the same inner fender and upper control arm as the A bodies. The steering arms, links and such are different, as are the lower control arms. I'd really like to install a different K member with rack and pinion. I think that would be first before the extractors, as that type K member might take a different extractor/headers. Oz would know, but I'm not ready yet $$$ wise to even ask him.
Tom
author unknown
Re: Shorty TTI's
[Re: migsBIG]
#1405795
03/22/13 02:51 AM
03/22/13 02:51 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Yes, they do have some high prices, but they are the best ones for mopars around. They probably are just making enough to keep in business.
I'm not a cheapskate, despite what I previously wrote. I have TTIs in the Charger and had a set on the Frankenduster. I'm not against free enterprise. I feel that a company is a business, not a charity as well. Despite all that, I still feel that the money that they spent on research and development of their products should have been paid for long ago. It is an insult to see them continue to price their stuff at 4 times the cost of Hedman, Hooker or the other cheap parts .
Re: Shorty TTI's
[Re: Kern Dog]
#1405796
03/22/13 09:28 AM
03/22/13 09:28 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
I agree with what your saying . When I was buying headers I looked around and went with headmans. Looking around on various Mopar forums I found some STILL had to hammer TTI's to fit. NO WAY was I spending that kind of money on something I still had to take a hammer to. I'd build my own before I'd spend that kind of money. I would have built my current set but I was in a hurry to get it on the road. At some point it will be a fun project when the car is put away for the winter.
