#14051 - 01/11/05 08:48 PM 29 or 10 spline in my 89 pig.
I need to buy a new yoke, for my 8 ĺ 89 pig but I donít want to open it now, can anybody tell my if there is any chance of it being a 10 spline or are all factory 89 pigs 29 spline, by the way itís a 3,91 if it makes any difference.
Thanks.
DKTA
#14052 - 01/11/05 09:26 PM Re: 29 or 10 spline in my 89 pig.
dave571 Offline
Loc: Carstairs, Alberta, Canada
Definately either way in aftermarket. I had this problem with a customers gear set.
I think you will have to look
www.davesmopar.com 11.85 @ 114,3890 pnds, all iron, hyd cam, 750 carb, 440, 3.73 gear Im a musician too www.davesmopar.com/davesmusic.htm
#14053 - 01/11/05 09:28 PM Re: 29 or 10 spline in my 89 pig.
DoctorDiff Offline
Loc: Polson, MT
If the pinion nut takes a 1 1/8" socket, you have a 10 spline pinion. If the pinion nut takes a 1 1/4" or 1 5/16" socket, you have a 29 spline pinion.
Contact info
#14054 - 01/12/05 06:25 AM Re: 29 or 10 spline in my 89 pig.
It is a 1 5/16'' so that clear.
Bundle of thanks.
25,349 Registered Members
190,249 Topics
Voltage drop during cranking
by AndyF
06/23/18 12:30 AM
Journey electrical question
by GKMOPAR
06/22/18 11:13 PM
Utiline '79 Power Wagon
by 4x4 Roundup
06/22/18 10:12 PM
Blowing off steam--pissed at Koni and Summit Racing
by Pacnorthcuda
06/22/18 09:31 PM
