Re: Max power air-fuel ratio for e10 fuel?
[Re: BradH]
#1405327
03/20/13 02:24 PM
03/20/13 02:24 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Brad, I have been running the O2 sensors for the last two years and I have been reading everything that I can to try and determine what the best A/F might be for my steup on E10. From what I have gathered, there might be a "range" to shoot for and then tweak from there. Since there are so many variables (outside temperature, octane, compression, timing, altitude, vehicle combo, etc.), I have been testing with 12.5-13.0 WOT A/F's for my WOT range. I do think that the "seat of the pants" shows that 12.8-13.0 feels quicker for my street car.
You will find that there are some people who will aim for 12.0 and some that will aim for 13.4. I was finding so many different opinions on what number to aim for, so I started testing different A/F numbers and found what my car seemed to like. Two years ago I aimed for 12.8-13.2. Last year I aimed for 12.4-12.8. This year I will aim for somewhere in the middle around the 12.8-13.0 range.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Dunnuck Racing]
#1405332
03/20/13 03:57 PM
03/20/13 03:57 PM
BradH
Stoich X 90 percent is a good general guideline . So approximately12.6 to 1 for E10. If you get a chance ,read my A/F article in the May Mopar Muscle. I gave some of the information there,on the track and dyno. Keith
I did pick up that issue (specifically because of your articles in it), but will go back and re-read the article.
I didn't remember you really finding a "sweet spot" during the e10 tests and the combination you ran seemed to want closer to 12.0 a-f IIRC.
[Re: YO7_A66]
#1405335
03/20/13 04:50 PM
03/20/13 04:50 PM
Posts: 16,925 NC
440Jim
NC
12.5-13.0 WOT A/F's
This is my opinion as well. Different combo's will use the fuel more efficiently, which allows a lean mixture for maximum power. Others don't atomize as well, scavenge/fill the cylinder, etc.
I think it is interesting to see tests, but I don't believe it will be the same answer for each application.
[Re: 440Jim]
#1405336
03/20/13 05:10 PM
03/20/13 05:10 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
12.5-13.0 WOT A/F's
That was the main point of the article. Too many guys are buying A/F meters then asking for a magic number to shoot for without realizing that their combination and even their fuel may make a difference Keith
That was exactly the point of my article . Too many guys look for a magic number to try and tune to with all the A/F meters out there now. But they have no idea how their combination or even their fuel compares to the guy they are asking. Keith
[Re: BradH]
#1405338
03/22/13 11:38 AM
03/22/13 11:38 AM
Posts: 16,925 NC
440Jim
NC
Brad, One other thing to remember... The wide band oxygen sensor actually measures Lambda, the ratio of actual mixture to stoichiometric mixture and it doesn't care what fuel you are running (100% gas, 95% gas, 90% gas, E85, alcohol, etc. i.e. it already accounts for the percent alcohol. The display device can be programed to show Lambda, or A/F based on the stoichiometric ratio you input.
I still like to talk in A/F ratio. So I convert Lambda to A/F based on 100% gasoline stoichiometric ratio of 14.7, this is called using the gasoline scale.
Gas: Lambda 0.85 x 14.7 = 12.5 A/F E85: Lambda 0.85 x 9.76 = 8.3 A/F Alky: Lambda .85 x 6.40 = 5.4 A/F And E10 might have a stoichiometric ratio around 14.3, FWIW.
From running all those fuels, the "best" Lambda is not significantly different for any of those fuels. So leave your display in gasoline scale and shoot for 12.5-13.0
