Re: HIlborn Mech. fuel injection on a street strip car?? [Re: 23T Hemmee] #1405313
03/21/13 03:15 PM
03/21/13 03:15 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Drag,
You've got an awesome looking setup, but you need to get the return spring on the same arm as the throttle cable, otherwise, you're twisting the throttle shaft everytime you open it up. Won't happen today, but somewhere down the line, it will eventually break the shaft at one of the butterfly slots......don't ask me how I know.....
Its on my wish list along with a better cable than a lokar, and to have it be allowed as legal in the Gasser Racing Series I race in...
Re: HIlborn Mech. fuel injection on a street strip car?? [Re: gregsdart] #1405314
03/21/13 03:20 PM
03/21/13 03:20 PM
When I see a street car with a Bugcatcher, Birdcatcher or Buzzard injector hat I really cringe and feel sorry for the driver of that car The first blown street hemi motor I assembled for a customer had one of those (Bird or Bugcatsher on it with EFI, I don't remember which size one now:o , 3300 CFM at WOT ) and it was a real bear and painful to drive at slow speeds on the street OP, if you do decide to buy a set of stack injectors and there is a choice on the butterfly sizes, smaller maybe easier to drive on the street
Re: HIlborn Mech. fuel injection on a street strip car?? [Re: Dragula] #1405315
03/21/13 03:23 PM
03/21/13 03:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My set-up...Seems a lot of people commenting that don't own one...
I see electronic injectors in those pictures so technically you don't own one either ...
Mine is efi...Its the best way to make mfi work on the street!
I agree with you , I was just pointing out the irony of your reply ...
Re: HIlborn Mech. fuel injection on a street strip car?? [Re: Cab_Burge] #1405316
03/21/13 03:46 PM
03/21/13 03:46 PM
gregsdart Online content
gregsdart  Online Content
One of the big injection companys has a diagram of linkages (Kinsler?)that produce extremely slow opening of the butterflys at off idle, and speed up to go one to one at WOT. That ought to solve that problem.
Re: HIlborn Mech. fuel injection on a street strip car?? [Re: Cab_Burge] #1405317
03/22/13 08:05 AM
03/22/13 08:05 AM
Dragula Offline
Dragula  Offline
Here is a vehicle startup and idle on a cold wintery day as we pulled our trailers into the convention center for a March indoor car show here in buffalo. I pushed the car out the trailer and hit the key...Ice cold! Most of the high end cars wouldn't even fire up...My trailer took two days to dig it out where I had it parked just prior to that show. The cam is a nice mild .+750" lift nasty with over 270° duration at 50...
Re: HIlborn Mech. fuel injection on a street strip car?? [Re: Dragula] #1405318
03/22/13 09:38 AM
03/22/13 09:38 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
What kind of ET did it put down with that combo?
68 Barracuda Formula S 340
Re: HIlborn Mech. fuel injection on a street strip car?? [Re: Bad340fish] #1405319
03/22/13 10:28 AM
03/22/13 10:28 AM
Dragula Offline
Dragula  Offline
I will have to get back to you on that...It was in the high 10's in testing, but it was killing valve train parts like they were candy with that cam. It should have been running low 10's high 9's, but coulda shoulda woulda.
Since then I have detuned the cam, ported the heads a little more, put all new valve train in and currently running a Prosystems carb to be legal. Its already back in the 10.90's and should be in the 10.70's when we get it back out next month.
If they allow Nostalgic looking efi into the GRS, then it will go back on with an XFI self learning computer instead of the current FAST batch fire computer....Either way, its a lot easier on parts, very drivable and still pretty fast for pump gas.
Re: HIlborn Mech. fuel injection on a street strip car?? [Re: Dragula] #1405320
03/22/13 11:08 AM
03/22/13 11:08 AM
NC
440Jim Offline
440Jim  Offline
NC
My set-up...
Now that looks cool.
Is it running alcohol or gasoline? OK, now I see your last post, gasoline. Much easier to start in cold weather than alcohol. My drag car has a gasoline primer system to make starting easier, then push the alcohol fuel shut off lever to ON for racing.
