temp gauge issue
#1404391
03/18/13 12:58 PM
03/18/13 12:58 PM
Posts: 4,179 California
mickm
California
this is the stock temp gauge on the 70 rallye dash. so i have my new engine in, and took it for a test drive. it was already about 170 when i took it out, but it seemed to climb quickly to 220+, so brought it back home. drove about a mile total. was able to remove the radiator cap, which seemed strange as it was supposedly so hot, and topped it off, (first time firing it in the car).
took it out again and same thing. again was able to take the radiator cap off. got hold of an infrared temp sensor, and the highest reading was 150 at the water pump neck. 140 at the top of the radiator, 110 at the bottom, all normal considering it was only driven a mile or so.
with my previous engine in there it would run around 180 or so, but seemed to heat up on the highway, and didn't like slow moving in hot weather. that all seemed reasonably normal.
how do i test the gauge and figure out what is wrong? unless the infrared sensor is wrong, (which i doubt, mainly because i was able to open the radiotor cap both times), then i've got another issue here.
another little tidbit, when i got the car, i discovered a 10 ohm resistor in line for the temp sensor. i took it out, and things seemed normal. so it may be possible that all this time my other engine was running cool?
thoughts?
Re: temp gauge issue
[Re: autoxcuda]
#1404393
03/18/13 01:38 PM
03/18/13 01:38 PM
mickm
California
When you redid the motor did you put a new temp sensor in it?
I've heard most of the new ones have the incorrect resistance and you have to add resistors.
Check you infered against a known source. But sounds like it is fine.
yes, temp sensor is new. i can put the old one in and see what happens...
[Re: mickm]
#1404394
03/18/13 01:49 PM
03/18/13 01:49 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
First thing I would do .
[Re: mickm]
#1404401
03/19/13 03:07 PM
03/19/13 03:07 PM
moparpollack
Lil Herman
Lil Herman
85086
Did you reuse the same carb as the old motor and how about the timing? Could need more fuel to keep her cool!
[Re: JohnRR]
#1404402
03/19/13 04:13 PM
03/19/13 04:13 PM
mickm
California
Is the location of the sensor in the same part of the waterpump housing on both engines ?
I have used a couple of MP alum housing and the temp sensor is located in a different location , I plug it and drill and tap it in the factory location.
Personally I wouldn't be relying on the factory gauge for accurate temp assessment .
yes, it is in the same location.
is there a way to have both the factory gauge hooked up as well as an aftermarket? i guess i could drill another hole, as you suggested above.
[Re: moparpollack]
#1404403
03/19/13 04:15 PM
03/19/13 04:15 PM
mickm
California
i know it's not running too lean. and the infrared is showing normal temps all around the cooling areas and heads.
i guess i could just slip a resistor in line...
i really do want to keep the stock gauge working. i hate seeing dead gauges on the dash.
[Re: autoxcuda]
#1404406
03/19/13 04:44 PM
03/19/13 04:44 PM
mickm
California
Just add resistors and calibrate it to your infered gun.
Sintro once suggested the ohm resistance amounts to start out with. They come in a pack from Radio Shack.
yeah, that certainly seems like the easiest way to go. short of finding an NOS sender...
[Re: Andrewh]
#1404408
03/19/13 05:04 PM
03/19/13 05:04 PM
mickm
California
does your gas gauge read high as well?
can you check the voltage out of the VR?
my gas gauge is a whole nother post's worth of issues!
no, it reads low, like at least 1/2 tank low.
i was thinking of checking the voltage at the gauge, but i need to know what range i'm looking for.
