70 T/A 4 speed with a mallory high fire ignition box. Everything else is stock, except electronic dizzy that runs off the mallory box. So I turn the key to start it, it cranks, but will not fire. I turn the key to run and jump the solenoid and it fires instantly. It worked fine for a while and now this started doing this. I replaced the ignition switch and starter relay for shots and gaggles, I'm ready to short the whole dash and let it burn!!!!!! I'm tired of fighting with myself.
Thanks for the help!!!
