1971 Challenger R/T trunk #1401062
03/11/13 11:07 PM
03/11/13 11:07 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang...
I'm just curious. I'm putting together my buddy's '71 Challenger R/T. I'm a B-body guy and learning a lot on these E's..... On the rear trunk harness routing, does harness route over the top center of the wheel well housing or dip down forward of the wheel well housing and run along the inside junction of the housing and trunk floor. Also, there's the white plastic retainer that's incorporated on the harness. I'm sure it is suppose to push over one of the tabs tack-welded to the floor pan by the jack...
Thanks in advance for any pictures and/or mentoring....
Troy
Houston Mopar Connection Club
Re: 1971 Challenger R/T trunk [Re: hemi68charger] #1401063
03/11/13 11:08 PM
03/11/13 11:08 PM
Houston, Tx
Houston, Tx
Old Harness with two retaining tabs that were once attached to the floor pan? Maybe the body shop accidentally ripped them off?
Troy
Re: 1971 Challenger R/T trunk [Re: hemi68charger] #1401064
03/11/13 11:37 PM
03/11/13 11:37 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
The tail light harness on e-body challenger runs up and then along the underside of the trunk gutter channel.
There should be a small tab welded to the underside of the trunk gutter that the white plastic retainer slides over. The tab is then bent over to secure and hold the harness. Depends on the year but there is also a tab located on body panel where the the tail lights mount
Re: 1971 Challenger R/T trunk [Re: C_B5] #1401065
03/12/13 08:38 AM
03/12/13 08:38 AM
Houston, Tx
Houston, Tx
Thanks Chas...
For anyone, pictures would be greatly appreciated..
Troy
Re: 1971 Challenger R/T trunk [Re: hemi68charger] #1401066
03/12/13 10:52 AM
03/12/13 10:52 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks Chas...
I'll post the factory prints tonight when I get home, I have all the E body electrical prints, front to rear, top to bottom, etc so if you need anything else just ask
Mike
Mike
Re: 1971 Challenger R/T trunk [Re: DAYCLONA] #1401067
03/12/13 11:19 AM
03/12/13 11:19 AM
Houston, Tx
Houston, Tx
Thanks Chas...
Mike
Mike
Thanks Mike..
Troy
Re: 1971 Challenger R/T trunk [Re: hemi68charger] #1401068
03/12/13 06:42 PM
03/12/13 06:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hope this helps Troy.....
Re: 1971 Challenger R/T trunk [Re: DAYCLONA] #1401069
03/12/13 06:43 PM
03/12/13 06:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 1971 Challenger R/T trunk [Re: DAYCLONA] #1401070
03/12/13 06:44 PM
03/12/13 06:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 1971 Challenger R/T trunk [Re: DAYCLONA] #1401071
03/12/13 06:50 PM
03/12/13 06:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
OK, this print is just for the 71 Challenger,...the pic posted above is for the 70 Challenger, I'll leave that one up in case someone needs it...
Mike
Re: 1971 Challenger R/T trunk [Re: DAYCLONA] #1401072
03/12/13 10:51 PM
03/12/13 10:51 PM
Houston, Tx
Houston, Tx
Mike...
Thanks a lot... Wow... So, the '71 harness runs along the TOP of the quarter next to the drain channel... mmmmmmmmmm I'll have to check this out.....
Troy
Re: 1971 Challenger R/T trunk [Re: hemi68charger] #1401073
03/13/13 08:50 PM
03/13/13 08:50 PM
Houston, Tx
Houston, Tx
Hey Mike !!!!!
Man-oh-man........ After seeing your '71 file, I got home and immediately went to the garage. Stuck my head in the truck with a flashlight and low and behold !!! The harness tabs are there... Don't disown me, I know the harness doesn't have the protective netting sheath on it.. What's up with that? I'll tell my buddy, but it's probably not a big deal to him....
Troy
