Brake Booster Size? #1400995
03/11/13 07:49 PM
03/11/13 07:49 PM
California, USA
filmsurgeon Offline OP
California, USA
Can someone tell me how brake boosters are measured? I assume the stated measurement pertains to the housing diameter (for instance: an 8" dual diaphragm booster would be 8" diameter). Is that measurement: the diameter of the back or front housing, or is it the diameter of the where the two halves join (which technically would be the largest diameter)? Thanks.
Re: Brake Booster Size? [Re: filmsurgeon] #1400996
03/11/13 08:34 PM
03/11/13 08:34 PM
IN
ahy Offline
ahy  Offline
IN
I believe it is the measure of the diaphragm itself which would be slightly smaller than the largest diameter. Maximum force varies with diaphragm area. Area varies with the square of diameter.
for a single 9': 9x9=81
for a dual 8": 8x8=64 times 2=128
The dual 8" would have about 60% more force vs a single 9"
