Re: ENGINE STARTS BUT WILL NOT STAY RUNNING
[Re: Jim_Lusk]
#1400928
03/11/13 06:55 PM
03/11/13 06:55 PM
Posts: 2,138 tucson az
frank
tucson az
The problem is likely that you do not have the hot wire in the run position connected to anything. This would be the wire that goes to the "other" side of the ballast with a normal ignition setup.
What should I connect that wire too?
[Re: frank]
#1400929
03/11/13 07:01 PM
03/11/13 07:01 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Is the blue wire that would normally go to a stock coil constant 12 volts? Would the fuel pump wiring have any effect on ignition? What do you think might be causing this condition?
The coil (your blue wire) will not be a full 12V in the run position. It should have been stepped down by the ballast resistor to something like 4-5V. The full 12V gets applied to the ballast which is a resistor which drops the voltage to the factory coil. My experience with this coil is to use the MSD ballast resistor which is lower than the factory unit but this wouldn't be the issue right now...
This blue wire should have voltage when the key is in run or start. I think it may be full 12V when in start but not in run (reduced voltage from ballast). If no voltage on coil when in run, then likely a dud ballast!
If the positive terminal of your coil is getting voltage when the key is in the run position (even after engine dies), then it's likely not a wiring issue (move on to dizzy or pump). Also, make sure the fuel pump isn't cutting off somehow after the motor dies. You did use the right place for the fuel pump to tap into though!
[Re: RapidRobert]
#1400932
03/11/13 09:27 PM
03/11/13 09:27 PM
frank
tucson az
The car has a new “stock” engine wire harnesses installed.
Need fire to the coil positive primary terminal & to the MSD in crank (ign2) & run (ign1, the blue wire circuit which has no fire right now). I'd connect the 2 female connectors together on either side of the harness where the ballast resistor was originally supposed to go & I think you'll be good.
Copy all. I'll connect them and see what happens. I didn't connect them before because I'm using one end (single blue wire) for power to the fuel pump relay with the key in the run position.
