spark plugs #1400425
03/10/13 06:52 PM
03/10/13 06:52 PM
Virginia
hokies1 Offline OP
hokies1  Offline OP
Virginia
I got a 416 stroker motor with indy X cast heads. I need a good spark plug. It has 10:5 compression. thanks
Re: spark plugs [Re: hokies1] #1400426
03/10/13 10:03 PM
03/10/13 10:03 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
NGK BCP6ES stock # 4930. Gap at .035 for points or factory electronic, .045 for CD ignition. This is a 5/8 in. hex plug so it will work on either iron or aluminum heads.
