Electronic ignitin trouble-guesses/answers?
#1400406
03/10/13 06:41 PM
03/10/13 06:41 PM
Posts: 942 Virginia, US
RTDaddy
super street
super street
Virginia, US
Got one of the Mopar performance electronic kits in a 440. Kit 8 years old, (yup have had to replace the control box a few times). Parked car about a month ago, running fine, no skips etc. Tried to start this morning, no spark. (This determined by holding a spare plug against the neg batt. terminal with #1 wire hooked to it, spinning motor over. Changed control box, no go. Checked ground to control box, (OK). Changed coil, changed to a new in box distributor, checked wiring from 5 pin connector to resistor, coil, etc, all good. With key in "run" position, have 12 volts on both sides of resistor. Using remote switch, spinning motor over still no spark using spare plug test. Anyone got any ideas? Not sure what may have happened while car was just setting. Oh yes, rotor button IS turning. "IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Electronic ignitin trouble-guesses/answers?
[Re: RTDaddy]
#1400409
03/10/13 11:12 PM
03/10/13 11:12 PM
RapidRobert
What Stump said pull the yellow wire off of the starter relay to disable the starter then have someone hold the key to start & at that point (1) the coil positive primary terminal and (2) the wire at the "point" of the ECU pentastar need fire (use a test light or VOM). If no fire at both what Franken said work back toward the bulkhead for the open. You mentioned the MP "kit" so I'm assuming this is a 4 pin ECU. If a 5 pin then 2 terminals on the pentastar connector need fire in "start". The ECU you've replaced it wouldn't happen to be orange in color would it . EDIT Check the reluctor gap in the new dist which ain't the original cause of the no start but is commonly misadjusted
[Re: RTDaddy]
#1400410
03/11/13 12:05 AM
03/11/13 12:05 AM
Posts: 5,445 So Cal
Sinitro
So Cal
Check the reluctor gap clearance.. Should be 0.008 using a brass feeler gauge, if too wide the box won't fire.. Just my $0.02...
[Re: Kern Dog]
#1400412
03/11/13 11:55 AM
03/11/13 11:55 AM
Posts: 5,445 So Cal
Sinitro
So Cal
Define..."Too wide". Mine had slipped to .020 and the car started and ran fine until I leaned on it, then it spit, sputtered and popped. This was unfortunate, because I learned this while trying to drag race in front of plenty of people! What a pisser, too. Back at home doing the Mopar CSI, I determined the wide gap was the cause of the misfiring. Once corrected, all was well again.
Factory spec is 0.006-0.008, but also other factors can influence its contact closure integrity as well..
In my RR, I installed the Mopar electronic ignition kit and everything started and ran fine. A couple of months later (September) we were going to a car show/cruise up the coast in Santa Barbara and stopped for lunch. When we came out to continue the cruise the RR wouldn't start, crank but no fire.
I checked connections, wires everything was fine. Popped off the distributor cap and saw the reluctor gap looked wide, not having a feeler guage with me I used a business card for setting its clearance..
Hit the key and it fired up.. Note that day it was kool and temperature has something to do with how well the magnetic pickup works for closing the circuit to fire the box. So it is a good idea to check this spec, even for new out-the-box installs.. Once it is set things are fine..
Just my $0.02..
[Re: Sinitro]
#1400413
03/13/13 02:14 AM
03/13/13 02:14 AM
Posts: 960 Chicago
PurpleBeeper
Chicago
Another possibility is that the magnetic pickup in the distributor is actually bad itself.... had that happen to me once. It also could be a bad cap, rotor, or the coil-to-cap ignition wire is burnt/broken or one of the ends pulled off.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
