BB 727 transmission coolant lines? #139906
10/22/08 08:19 AM
10/22/08 08:19 AM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
Which transmission coolant line goes to which input on the
radiator? In other words does the rear input on the transmision go to the drivers side input on the radiator or is it the other way around?
Re: BB 727 transmission coolant lines? [Re: 74RR] #139907
10/22/08 08:23 AM
10/22/08 08:23 AM
NY usa
540challenger Offline
NY usa
If i remember right the front must line of the transmission "out" goes to the passenger side of the rad. "in"
Re: BB 727 transmission coolant lines? [Re: 540challenger] #139908
10/22/08 11:27 AM
10/22/08 11:27 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Torqueflite Fluid Flow
Re: BB 727 transmission coolant lines? [Re: 74RR] #139909
10/22/08 11:36 AM
10/22/08 11:36 AM
74RR Offline OP
74RR  Offline OP
Thank you guys for the replys'!
