2.5 or 3" exhaust? 68 dart 360 #1398702
03/07/13 05:58 PM
03/07/13 05:58 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
Im putting exhaust on my dart, mostly stock 360. In a few years I'm planning on a 408 stroker. Should I go with 2.5 or 3" exhaust?
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: GTSDart340] #1398703
03/07/13 06:45 PM
03/07/13 06:45 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
2.5" is plenty as the guys in the fast series are running 2.5" and running in the 10's
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: GTSDart340] #1398704
03/07/13 06:55 PM
03/07/13 06:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Go 3" flows 40% more!
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: rapom] #1398705
03/07/13 06:56 PM
03/07/13 06:56 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
2.5" is plenty as the guys in the fast series are running 2.5" and running in the 9's
fixed
I think 3" would be too much on a 360 ... then again they put 5" on a 5.9 cummins
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: rapom] #1398706
03/07/13 06:58 PM
03/07/13 06:58 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
HELLO IF YOU ARE GOING TO PUT NEW EXHAUST ON I WOULD GO THE THE 3" THEN WHEN YOU PUT THE 408 IN IT WILL ALREADY BE THERE . I RUN 3" ON ALL OF MY BIG ENGINE CARS THAT MY
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: GTSDart340] #1398707
03/07/13 07:23 PM
03/07/13 07:23 PM
3". I believe any neckdown aft of the header collector restricts flow & therefore hurts power & you want no restriction & the least amount of backpressure from there rearward in a 4 stroke eng. Gas speed/scavenging is a seperate pri tube dia/length issue. But a 3" setup is going to be VERY loud & you'll need every ex trick in the book to make the noise liveable, X pipes, addit'l glasspack muffs alongside the leaf springs & maybe add some sideways capped 1.5 ft long pipes welded to the 2 bends over the axle (helmholtz resonators iirc). Ain't tried it but reportedly it is an accoustical godsend for noise reduction. Best might be those trick muffs that open up when you get on it I forget what they are called or some cable or electric operated cutouts along with restricted muffs (keep em quiet till the money is in the hands of a neutral 3rd party ). 2.5" would be troublefree. 3" would be a certain amount of gain but would be alot more work/planning. Mandrel bends everywhere.
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: GTSDart340] #1398708
03/07/13 07:43 PM
03/07/13 07:43 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Don't bother with 3" unless you plan on over 500hp. Also, don't negect the muffler selection.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: DPelletier] #1398709
03/07/13 08:01 PM
03/07/13 08:01 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
whats the point in building a 408 if you are not shooting for that kind of power?
i say go for it and like said before chose the right mufflers for it!
3" usualy gives a nice deep sound
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: DPelletier] #1398710
03/07/13 09:05 PM
03/07/13 09:05 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
x2
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: MoparMarq] #1398711
03/07/13 09:20 PM
03/07/13 09:20 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: pinkduster] #1398712
03/07/13 10:01 PM
03/07/13 10:01 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
As usual the original poster didn't really indicate what his intended use for the car will be. Is it a race only drag car, or a weekend cruiser, or a daily driver.
As others have stated, 3" will be very loud inside the car. And in my opinion is overkill. But if your just racing who cares how loud it is. If its a driver or a cruiser, the loud pipes can get old very quickly.
I read an article a couple years ago and i'll try to relay what it said even though I may be using the wrong scientific terms. But basically what its said was the by the time the exhaust gets through the mufflers, a large portion of the heat energy has been disapated, or maybe it was back pressure, anyway, it stated that you could do like 3" pipes from the headers to the mufflers, and then go 2.5" from the muffers out the back tailpipes and you wouldn't really be creating any extra back pressure by having the smaller tailpipes. But the car would be quieter with the smaller tailpipes.
Wish I could find the article, I'm sure its explains it better than I did.
Anyway, I would stick with 2.5" pipes if the car sees any amount of street use, just to keep the noise down.
Good luck
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: MileHighDart] #1398713
03/07/13 11:02 PM
03/07/13 11:02 PM
Laveen, Arizona
Laveen, Arizona
Its going to be a street car, but not a daily driver.
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: GTSDart340] #1398714
03/08/13 12:47 AM
03/08/13 12:47 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I see you came to ask the professionals. I think 2.5" would be plenty. You will be fast enough, and light enough, to beat all your brothers and their GM cars.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: GTSDart340] #1398715
03/08/13 01:00 AM
03/08/13 01:00 AM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
I went through this same thing last summer with
my Duster! I have a mild 360 currently as well.
I debated and went back and forth for weeks...
deciding on what to do. Since mine is just a
weekend summer cruiser (car show/cruise nite/ice cream runner type Mopar)...I went with a header back Jegs(Pypes) full 2-1/2 inch kit which is a nice kit IMO.
All aluminized mandrel pre-bent tubing with
(optional H-pipe) which I got.
I wanted to go the full exhaust route, with 2.5" stainless steel tips. I had a local
muffler shop do the work,because I wanted everything welded properly. They had an easy time until they assembled the 2.5" tailpipes next to the factory gas tank. It took them quite awhile to get the fitment just right on the pass. side pipe...between the tank and leaf spring.
IT'S TIGHT THERE! The system turned out great though,sounds awesome with Flowmaster 2 chambers.
So....if you are thinking of going with a 3 inch system out the back...think twice about the gas tank issue! Good Luck!
Plymouth Makes It!
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: RoadRunnerLuva] #1398716
03/08/13 04:29 PM
03/08/13 04:29 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Yep I put that kit on my 73 swinger- the passenger side over-axle isn't quite right. I had to do some surgery to get it right. Still was cheaper and easier than going to the local shop with a non-mandril bender that's going to try and sell you flowmaster 40s!
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: MileHighDart] #1398717
03/08/13 04:47 PM
03/08/13 04:47 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Good luck
Have read similar articles and his summation is not far off.
Tailpipes are an oft-overlooked key in noise control. Size and location of the turndown are key.
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: Fury Fan] #1398718
03/08/13 06:56 PM
03/08/13 06:56 PM
montana
P
pjc360 Offline
pjc360  Offline
P
montana
i'd go with dual 2 1/4 inch pipe, a dual 2 1/4 inch exhaust is enough to support 450 horse power, you dont want to lose scavenging affect.
I know a guy who runs a 408 stroker magnum thats real close to 450 hp and he runs hedman hedders 1 5/8 primary hedder tube into a dual 2 1/4 inch exhaust with an H pipe and his car runs just fine with the exhaust set up he has.
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: GTSDart340] #1398719
03/08/13 07:36 PM
03/08/13 07:36 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
3" is just silly for a 408, even more stupid for a 360 in a dart!!
You guys are a riot.
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: Challenger 1] #1398720
03/08/13 09:03 PM
03/08/13 09:03 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
3" is waaay overkill. Racecar, maybe... but not on the street.
Re: 2.5 or 3" exhaust? 68 dart 360 [Re: drew72] #1398721
03/08/13 09:42 PM
03/08/13 09:42 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
lmao!!!!
You guys should just go with something like this. I mean, you wouldn't want to disturb the neighbors with some three inch now would 'ya.
