Trickflow BB head bolts...ABN stamped #1398135
03/06/13 04:47 PM
03/06/13 04:47 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I have a set of BB head bolts that were Trickflow branded. The bolt heads have ABN on them. I wonder if they are worth a hoot, or some offshore junk??
Anybody?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Trickflow BB head bolts...ABN stamped [Re: Von] #1398136
03/06/13 05:13 PM
03/06/13 05:13 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I don't know if this will help any or not but check out this link. When I talked to the trick flow guys about doing a small block mopar head at the Halloween classic I am pretty sure Summite owns Trick Flow.
http://www.trickflow.com/egnsearch.asp?N=400098++4294925232+115+346418&autoview=sku
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trickflow BB head bolts...ABN stamped [Re: Von] #1398137
03/06/13 05:31 PM
03/06/13 05:31 PM
dogdays Offline
dogdays  Offline
The head marking is required on US bolts. ABN is the marker for Auto Bolt & Nut, Cleveland, OH.
Sounds good to me!
R.
