Where to find a heater core? #1397779
03/05/13 06:05 PM
03/05/13 06:05 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I need a new heater core for the Imperial. It's a twin core unit similar to this:
The radiator shop I use is a great place that has been around since the 40s. They usually find anything I need. This time around they've drawn a blank. There are apparently no 1972 Imperial heater cores to be had.
They tried ordering similar size cores that could be modified to fit my car but there are none available in the correct width.
The cores measure 8-3/4 x 6-3/8 x 1-1/2. Custom cores could be made but I'd be facing $400 or more.
Do you guys have any idea where I could find heater cores?
- Stu Harmon
Re: Where to find a heater core? [Re: feets] #1397780
03/05/13 07:07 PM
03/05/13 07:07 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i had the same problem finding one for my 65 coronet, they are not made. if you do not use the heater, remove the heater hose fittings from the block, weld them closed, put them back on and slip the hoses back on. thats what i did.
Re: Where to find a heater core? [Re: 65rbdodge] #1397781
03/05/13 07:28 PM
03/05/13 07:28 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
This is not a hot rod. It is an Imperial luxo cruiser. It will have a working heater.
I planed on running up to 14,000 feet in a couple weeks. A heater would be nice.
- Stu Harmon
Re: Where to find a heater core? [Re: feets] #1397782
03/05/13 07:52 PM
03/05/13 07:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Couldn't you just go with a single core and adapt it to work? It looks like you could get away with half the core if necessary.
Re: Where to find a heater core? [Re: stumpy] #1397783
03/05/13 08:31 PM
03/05/13 08:31 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The evaporator is set up the same way. This is a reheat system. Air blows across the evaporator then hits the heater core. That dehumidifies the air. Modern cars do this too, especially on defrost.
I would get half warm air and half cooled air. If I were to choke it down to a single core I would lose half my air flow.
Still, the problem lies in finding a 1-1/2" thick heater core that will fit in the box.
- Stu Harmon
Re: Where to find a heater core? [Re: feets] #1397784
03/05/13 08:43 PM
03/05/13 08:43 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
What about Classic Auto air in Florida ?
Re: Where to find a heater core? [Re: a12rag] #1397785
03/05/13 08:52 PM
03/05/13 08:52 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
you know the answer to your question...sometimes you just have to pony up the dough and get it made. it sux but you wont be happy unless its right...I know I wouldnt
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Where to find a heater core? [Re: pnypwr] #1397786
03/05/13 09:10 PM
03/05/13 09:10 PM
Andrewh Offline
Andrewh  Offline
actually classic has a shop in grapevine or fortworth.
920 Minters Chapel Rd, Grapevine, TX 76051
(817) 442-4822
wouldn't hurt to call.
Re: Where to find a heater core? [Re: Andrewh] #1397787
03/05/13 09:54 PM
03/05/13 09:54 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'd suggest burning down the phone lines bugging every NOS guy you can think of. They would probably be happy it's going to a good home and off their shelf (unless you call a couple 'special' guys)...
Re: Where to find a heater core? [Re: feets] #1397788
03/06/13 12:29 AM
03/06/13 12:29 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I planed on running up to 16,000 feet in a couple weeks.
Where exactly are you planning to do that?
Re: Where to find a heater core? [Re: feets] #1397789
03/06/13 01:36 AM
03/06/13 01:36 AM
oklahoma
69suprbee Offline
69suprbee  Offline
oklahoma
I picked the one in your picture up last year at yearone for my 69 bee.
Re: Where to find a heater core? [Re: pnypwr] #1397790
03/06/13 02:03 AM
03/06/13 02:03 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I wonder if I have an old dodge truck heater core laying out that I could measure.....
Re: Where to find a heater core? [Re: 69suprbee] #1397791
03/06/13 02:08 AM
03/06/13 02:08 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
If you noticed he is using that picture for reference .
Re: Where to find a heater core? [Re: rss] #1397792
03/06/13 02:18 AM
03/06/13 02:18 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
OOPS!
How about 14,000 feet?
The idea was a run through Colorado. It's currently on hold pending the outcome of this issue.
- Stu Harmon
Re: Where to find a heater core? [Re: feets] #1397793
03/06/13 02:51 AM
03/06/13 02:51 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
F body cores are similar sized but a little thicker, maybe just under 2".
Re: Where to find a heater core? [Re: feets] #1397794
03/06/13 06:49 AM
03/06/13 06:49 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Here's one from Classic heaters...
http://www.classicheaters.com/
Scroll down to the catalog link & it's down the page there. There's 2 listed but ones out of stock. 249.00.
Classic auto air doesn't show them on the site anymore but this is essentially what they had.
Butch
Re: Where to find a heater core? [Re: pnypwr] #1397795
03/06/13 07:32 AM
03/06/13 07:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I might have a complet box from one of my 70 Imps.They all had good cores and were all Auto Temp cars.Let me know and Ill see if they are at the other garage.Rocky
Chrysler Firepower
Re: Where to find a heater core? [Re: therocks] #1397796
03/06/13 01:45 PM
03/06/13 01:45 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm not sure if the 70 was the same but I'd sure appreciate you looking at it.
- Stu Harmon
Re: Where to find a heater core? [Re: feets] #1397797
03/06/13 03:32 PM
03/06/13 03:32 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Might be this weekend before I make it over there.I know I had a couple of complete setups.My kids did scrap some stuff I had.Rocky
Chrysler Firepower
Re: Where to find a heater core? [Re: feets] #1397798
03/07/13 11:06 AM
03/07/13 11:06 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
OOPS!
For your planning purposes, Pikes Peak and Mt Evans will not be open til Memorial Day. Those are the only two places you can drive that high. Also, Trail Ridge Road (11,000 feet)may not be open until even later as the federal budget woes will not allow overtime to plow it open as quickly as in past years.
Craig
