Where to find a heater core?
#1397779
03/05/13 06:05 PM
03/05/13 06:05 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I need a new heater core for the Imperial. It's a twin core unit similar to this: The radiator shop I use is a great place that has been around since the 40s. They usually find anything I need. This time around they've drawn a blank. There are apparently no 1972 Imperial heater cores to be had. They tried ordering similar size cores that could be modified to fit my car but there are none available in the correct width. The cores measure 8-3/4 x 6-3/8 x 1-1/2. Custom cores could be made but I'd be facing $400 or more. Do you guys have any idea where I could find heater cores?
Re: Where to find a heater core?
[Re: 65rbdodge]
#1397781
03/05/13 07:28 PM
03/05/13 07:28 PM
feets
Senior Management
Senior Management
Irving, TX
This is not a hot rod. It is an Imperial luxo cruiser. It will have a working heater. I planed on running up to 14,000 feet in a couple weeks. A heater would be nice.
[Re: stumpy]
#1397783
03/05/13 08:31 PM
03/05/13 08:31 PM
feets
Senior Management
Senior Management
Irving, TX
The evaporator is set up the same way. This is a reheat system. Air blows across the evaporator then hits the heater core. That dehumidifies the air. Modern cars do this too, especially on defrost.
I would get half warm air and half cooled air. If I were to choke it down to a single core I would lose half my air flow.
Still, the problem lies in finding a 1-1/2" thick heater core that will fit in the box.
[Re: a12rag]
#1397785
03/05/13 08:52 PM
03/05/13 08:52 PM
Posts: 4,872 connecticut
pnypwr
connecticut
you know the answer to your question...sometimes you just have to pony up the dough and get it made. it sux but you wont be happy unless its right...I know I wouldnt
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#1397786
03/05/13 09:10 PM
03/05/13 09:10 PM
Andrewh
actually classic has a shop in grapevine or fortworth.
920 Minters Chapel Rd, Grapevine, TX 76051 (817) 442-4822
wouldn't hurt to call.
[Re: feets]
#1397788
03/06/13 12:29 AM
03/06/13 12:29 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
I planed on running up to 16,000 feet in a couple weeks.
Where exactly are you planning to do that?
[Re: feets]
#1397794
03/06/13 06:49 AM
03/06/13 06:49 AM
Posts: 1,652 Central Ky, area
CHRYCOFAN
Central Ky, area
Here's one from Classic heaters... http://www.classicheaters.com/Scroll down to the catalog link & it's down the page there. There's 2 listed but ones out of stock. 249.00. Classic auto air doesn't show them on the site anymore but this is essentially what they had. Butch
[Re: pnypwr]
#1397795
03/06/13 07:32 AM
03/06/13 07:32 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I might have a complet box from one of my 70 Imps.They all had good cores and were all Auto Temp cars.Let me know and Ill see if they are at the other garage.Rocky
Chrysler Firepower
[Re: therocks]
#1397796
03/06/13 01:45 PM
03/06/13 01:45 PM
feets
Senior Management
Senior Management
Irving, TX
I'm not sure if the 70 was the same but I'd sure appreciate you looking at it.
[Re: feets]
#1397797
03/06/13 03:32 PM
03/06/13 03:32 PM
therocks
Niles , Ohio
Might be this weekend before I make it over there.I know I had a couple of complete setups.My kids did scrap some stuff I had.Rocky
Chrysler Firepower
[Re: feets]
#1397798
03/07/13 11:06 AM
03/07/13 11:06 AM
Posts: 1,822 Colorado
denfireguy
Colorado
OOPS!
How about 14,000 feet?
The idea was a run through Colorado. It's currently on hold pending the outcome of this issue.
For your planning purposes, Pikes Peak and Mt Evans will not be open til Memorial Day. Those are the only two places you can drive that high. Also, Trail Ridge Road (11,000 feet)may not be open until even later as the federal budget woes will not allow overtime to plow it open as quickly as in past years. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
