Buying a cam..help me decide
#1397704
03/05/13 03:17 PM
03/05/13 03:17 PM
Posts: 126 kentucky
kyhemi-dart
kentucky
About to buy a can for my 340.
Motor is .30 over Ported J-heads Holley Strip Dom w/750 904 with 4500 conv 5.00 + gears
All going in a 3100 or so back halfed Dart. This motor is just filling the void until our hemi is done. Have my choices narrowed down to two.
MP 296 .557 cam or Comp Cams 290/304 .558/558. Anyone have expirience with the Comp Cam? I believe the .557 is 252 @ .50 and the Comp is 260/266 @ .50
Re: Buying a cam..help me decide
[Re: kyhemi-dart]
#1397706
03/05/13 06:22 PM
03/05/13 06:22 PM
Posts: 20,667 in a cattle trailer down by th...
Guitar Jones
You will need to wind that thing. Go big or go home, but since it's just a temporary engine, well, it may not perform all that well anyway. Those are some steep gears for those heads so with the smaller cams it will probably run out of breath by the 1000 foot mark.
[Re: kyhemi-dart]
#1397709
03/05/13 07:10 PM
03/05/13 07:10 PM
Guitar Jones
Itll have a 14.5w x 32 slick so the gear wont hurt it as bad as a small tire car
It will still need at least 7000 RPM.
[Re: kyhemi-dart]
#1397710
03/05/13 07:13 PM
03/05/13 07:13 PM
Posts: 1,532 off the grid
340B5
off the grid
As long as the comp ratio is 10:1 or more, I would highly recomend a Racer Brown ST-21 or STH-42. Same cam; one hyd and other solid. Your combo should run 11.70 to 11.90 with either.
Yeah, it's got a smallblock.
[Re: kyhemi-dart]
#1397711
03/05/13 07:17 PM
03/05/13 07:17 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'd use the Mopar cam. We've been using the Mopar cams since 1972 and have had ZERO problems. The payout window doesn't know what cam the engine has in it.
