98 ram wipers slow to start ? #1397614
03/05/13 10:41 AM
03/05/13 10:41 AM
ogletownpa
3
383'D Offline OP
383'D  Offline OP
ogletownpa
My 98 1500 ram wipers wont start immediatly after turning the switch on after it sits overnight.If I leave the switch on ,it will start after 30 seconds or so . All the delays and high and low work fine then.Its been doing this for 2 weeks and I need to find the problem. I tried banging on the switch and relay box under the hood but that had no effect.Im thinking maybe the cluster switch is the problem.
Re: 98 ram wipers slow to start ? [Re: 383'D] #1397615
03/05/13 11:00 PM
03/05/13 11:00 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Thy adding a ground wire to the motor. I just make up a short lead with 2 eye terminals and ground one end to the body and one to the armatures field housing bolt.
