SPINDALS #1397290
03/04/13 03:08 PM
03/04/13 03:08 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
WENT TO A TUBLER K MEMBER
ALL I CAN FIND IS 2 INCH DROP SPINDALS
ANY BODY KNOW WHERE TO GET SPINDALS WITH NO DROP?
Re: SPINDALS [Re: BUBBAZ572] #1397291
03/04/13 03:39 PM
03/04/13 03:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Which tubular K member?
Try searching for spindles or knuckles. That may clear up the results a bit.
- Stu Harmon
Re: SPINDALS [Re: BUBBAZ572] #1397292
03/04/13 05:01 PM
03/04/13 05:01 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Doesn't AJE supply those with their kit?
Since their stuff is all M2 based, I'd suspect you could find those spindles anywhere.
Re: SPINDALS [Re: TC@HP2] #1397293
03/04/13 06:26 PM
03/04/13 06:26 PM
San Diego
formula S Offline
formula S  Offline
San Diego
That stuff is junk
Re: SPINDALS [Re: BUBBAZ572] #1397294
03/04/13 06:29 PM
03/04/13 06:29 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Yep, "spindles" can be found in the Classifieds Section of this website. Just pick what bodystyle you want them from and go hunting.
Re: SPINDALS [Re: BUBBAZ572] #1397295
03/04/13 08:36 PM
03/04/13 08:36 PM
AndyF Offline
AndyF  Offline
If you want Mopar spindles then talk to Cass at DoctorDiff.com.
If your aftermarket K-frame uses Mustang spindles then you can get spindles anywhere.
Re: SPINDALS [Re: AndyF] #1397296
03/04/13 09:01 PM
03/04/13 09:01 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
SPINDLES
