I need some help in understanding the Cam Sensor and Trigger Wheel. This is from my Gen 3 Hemi. Based on the design of the trigger wheel, the Cam Sensor must actuate when it hits an opening. The ring has 8 equally spaced openings, which makes sense. But, what I don't understand is, some of the openings have two additional openings or one additional opening. What are the purpose of the additional holes, and why are they not the same for every cylinder?
First Pic shows 3, then one, then one.
Next is 2, then 3, then 2
Lastly 2, then one
