Re: Strange bubbling sound from Gas Tank - 1970 B-Body
[Re: jcastle1]
#139678
10/22/08 07:23 AM
10/22/08 07:23 AM
Challenger 1
Cincinnati, Ohio
I experienced the exact same thing just two weeks ago,except for the gas spilling onto the floor. I crawled under the car and could hear it coming from the gas tank,and when I removed the gas cap it was quieted instantly. I don't know why it did this????
I think it is the fact that the gas is coming out of the ground cool at about 60 degrees and putting it in your 90 degree gas tanks and is expanding. That's why vent/vapor lines are important not to do away with. Plus the heat radiating off the hot asphalt heats up the gas in your tank.
[Re: dg_dodge]
#139681
10/22/08 06:49 PM
10/22/08 06:49 PM
Posts: 216 united kingdom
Simonic
united kingdom
My car (68superbee) does this also,i have a vent tube just like yours which just seems to hang in space,i don't know if this is correct or not. if the tank is full or near full i get a small puddle of fuel on the floor. when i open the tank cap the noise stops and i can hear some pressure escape. this happens more on a hot day
Keeping the Bee Buzzin'
[Re: R/T1968R/T]
#139683
10/22/08 07:25 PM
10/22/08 07:25 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Looks like the wrong cap. Thats an emission cap that doesnt vent into the atmosphere.Its letting the pressure build up. I dont have a picture of an early cap though sorry.
Yes wrong cap, press/vac cap will hold just that press or vac. You need a cap that says vented, you should also hook up the tank vent properly.
