Re: Want to build a pump gas, low compression stroker 360. [Re: HealthServices] #139660
10/23/08 10:22 AM
10/23/08 10:22 AM
Table Rock Lake Missouri
furious Offline OP
furious  Offline OP
For my situation, you make a great case. I am seriously considering it. Thanks!
One think I didn't find an answer to. Back when we would run Methanol in our race cars, it would "milk" the oil with one night of drag racing. Does E85 do that?
Re: Want to build a pump gas, low compression stroker 360. [Re: furious] #139661
10/23/08 12:38 PM
10/23/08 12:38 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I think you wet down the cylinder walls and the fuel passed the rings and into the oil.
The one big thing I did not find out much is Water. With wood alcohol there is a tendency for it to be hydroscopic (sp?) meaning it likes to absorb water. So I do not know much about how storage would be with the material in the car for long periods.
You may want to do a search in the 'Unlawfl's Race Only' section since there are several in there that race with just E85.
I am still researching it myself and like I said would have already converted but there are basically only 2 stations in all of southern California
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Want to build a pump gas, low compression stroker 360. [Re: HealthServices] #139662
10/23/08 01:03 PM
10/23/08 01:03 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
I see at least 4 here:
http://e85vehicles.com/e85-california.htm
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: Want to build a pump gas, low compression stroker 360. [Re: kick_the_reverb] #139663
10/23/08 01:19 PM
10/23/08 01:19 PM
So Cal
So Cal
I may actually consider it if I was in diego land but only two are within 60 miles of me. Both are over 50 miles away. Not too convenient. I'm in the oc.
Re: Want to build a pump gas, low compression stroker 360. [Re: HealthServices] #139664
10/23/08 03:35 PM
10/23/08 03:35 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Whats the compression on the currant motor ? are the pistons domed or flat top ? what does it have for a cam ? It has iron heads ?
You could look in to changing to an aluminum head and/or play with cam timing.
