Re: drive shaft strength
[Re: mopar dave]
#1396634
03/03/13 11:31 PM
03/03/13 11:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
had my d shaft shortened. the place that did the work says its only good to 600hp. steel 3" .083" wall thickness and spicer 1350's. what do you guys think would be max power-torque off t brake with 3300# car? thanks
A 3" DOM would be much better... I use a 3.5" at 39" on the Rampage and thats 550hp but its only a 7000 rpm engine and torque is 520
[Re: mopar dave]
#1396636
03/04/13 11:55 AM
03/04/13 11:55 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
That is how it is formed Drawn Over Mandrel different then Electric welded, you do not see a seam on DOM
"Just a Bracket car dressed up like a streetcar"
[Re: mopar dave]
#1396637
03/04/13 11:56 AM
03/04/13 11:56 AM
Posts: 7,506 Az
Crizila
Az
whats DOM?
Drawn Over Mandrel. It's a step above rolled tubing strength wise. Most stock shafts are rolled and welded. I assumed that you had a DOM shaft. If not, you definitely need to go that route no matter what size tube you use.
Fastest 300
[Re: mopar dave]
#1396639
03/04/13 07:25 PM
03/04/13 07:25 PM
Triple Threat
Renton Washington
They're talking about the tube itself, not the welds to the yokes All of the cheap driveshafts, roll cages etc use ERW tube instead of DOM. DOM is stronger but more expensive. ERW = Electric Resistance Welded DOM = Drawn Over Mandrel
[Re: mopar dave]
#1396640
03/04/13 08:11 PM
03/04/13 08:11 PM
MR_P_BODY
Mines welded on both ends
If he said Steel.... thats mild steel(with the seam)... at the length and your dia you want DOM
[Re: mopar dave]
#1396642
03/04/13 10:48 PM
03/04/13 10:48 PM
MR_P_BODY
Ok than. Mine is Dom,no seam. A driveshaft shop in Lansing made it. I think there gone now.
If its painted you most likely wont see the seam... the outside of the seam is scraped clean during the welding process... the inner isnt scraped... if its not painted you will see a blue line if its mild steel
[Re: mopar dave]
#1396644
03/06/13 01:34 AM
03/06/13 01:34 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Driveshafts don't really 'see' horsepower but will certainly have a torque limit. OE shafts are only 0.060" thick and unknown material and have been used in much more demanding applications reliably. I think you've got plenty of safety factor and shouldn't worry about it. Of course that's assuming it's in good condition without dents or scrapes and with minimal runout.
[Re: @#$%&*!]
#1396645
03/06/13 01:45 AM
03/06/13 01:45 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
I just ordered up a set of 3.5" 1350 spicer shaft ends and a 3.5" spicer .083 tube....shipped was less than 120$.....
welding it up to 53.5 center to center and using my hardened moser powerglide yoke I already had...using my old spicer 1350 solid u-joints I got laying around....
Lets see if it will hold up behind the twin 408 in the 5th aveneu!....oh yea, the spicer tube is welded seam...I just can't see spicer selling it if it can't handle a lot of brute force!!!!!!!
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: mopar dave]
#1396647
03/06/13 03:59 PM
03/06/13 03:59 PM
MR_P_BODY
I think my d shaft is the mild steel. says custom steel on receipt,what ever that meens. does have seem down the middle longways. called dennys d shaft. he recommends the nitrous ready 3" with spicer 1350's. good to 700hp and with cm slip joint good to 800. look like i'm gonna have to speed some money.
Call Dynotech down here in Troy
