Rack and pinion swap on 84 D-150 #1396293
03/02/13 10:24 PM
03/02/13 10:24 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
It has been a few years, but I remember seeing pics of a rack and pinion setup that was tabbed on an 80's race truck.
I have searched for them, no luck. I do member the truck was blue.
A thread link would be great. I want to do this swap. I work as a fabricator for a trucking company, just want to see how he placed the mounts .
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396294
03/02/13 11:18 PM
03/02/13 11:18 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Believe its Clutches truck.
Re: Rack and pinion swap on 84 D-150 [Re: 76dodgeboy] #1396295
03/02/13 11:19 PM
03/02/13 11:19 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Front
Re: Rack and pinion swap on 84 D-150 [Re: 76dodgeboy] #1396296
03/03/13 12:44 AM
03/03/13 12:44 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
I must be tired ... in the front shot, at first glance I thought it was a NUN driving ...
It takes gasoline to interest me.
Re: Rack and pinion swap on 84 D-150 [Re: VL21] #1396297
03/03/13 06:24 PM
03/03/13 06:24 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
I copied clutches set up on my current build. It is a 1st generation manual Dakota rack(kinda hard to come by) I sent clutch several PM's so that I was crystal clear how he did it.
I don't have my laptop so I can't post pics, but here is a link to another thread I posted pics on.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Rack and pinion swap on 84 D-150 [Re: VL21] #1396298
03/03/13 11:23 PM
03/03/13 11:23 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
If he was a Nun he'd be the "Flying Nun"!
Re: Rack and pinion swap on 84 D-150 [Re: Flite_727] #1396299
03/04/13 01:27 AM
03/04/13 01:27 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Thanks Flite!
That looks good. So I take it ya swapped the lca's side for side . Do the strut rods go back to the front like stock ok, or are there mods there too?
Although it isnt Mopar parts, I have seen a few Crown Vic front suspensions put under ferd trucks. Pretty sweet swap. Good disc brakes and rack and pinion steering to boot. Way lighter than the stock crossmember too! Is also 4 1/2" bolt pattern wheels. So far it looks like the crown vic setup is how I will probably do mine. Oh, also, it bolts in easily, but I am sure I would weld mine in.
84 D150 440/727
79 /6 swb D150
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396300
03/04/13 03:52 AM
03/04/13 03:52 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Grind the area around the bushing to clear frame
Cut van steering stop off
Drill holes for truck strut rods
Cut bump stop off frame
Drill tabs on frame to 3/4"
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396301
03/05/13 12:04 AM
03/05/13 12:04 AM
Flite_727 Offline
Flite_727  Offline
Thanks Flite!
Everything is stock. D series trucks are front steer to begin with. The centerline of the rack runs through the same centerline as the stock inner tie rod ends with the tires pointed straight ahead.
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396302
03/05/13 01:05 AM
03/05/13 01:05 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Thanks Flite!
Ive actually been reading about this today and it seems like a good idea. anybody know how wide the d100 frame is outside to outside?
Re: Rack and pinion swap on 84 D-150 [Re: 72d100] #1396303
03/08/13 12:30 AM
03/08/13 12:30 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
I made a deal today over the phone on a cop car crown vic front frame clip from firewall forward. they are going to remove the steering shaft from the column and throw it in. I thought I couldnt pass it up for $ 150!
I am going to pick it up Saturday morning.
Headed for the shop after work tomorrow to remove the front sheetmetal, slant six and 4 speed.
Going to start removing front suspension, crossmember etc after I get the clip hauled in Saturday.
I cant wait to get going on this!!!
84 D150 440/727
79 /6 swb D150
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396304
03/08/13 12:42 AM
03/08/13 12:42 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
what year front end did you pick up?
Re: Rack and pinion swap on 84 D-150 [Re: 72d100] #1396305
03/08/13 12:43 AM
03/08/13 12:43 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
2010 is what they told me.
84 D150 440/727
79 /6 swb D150
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396306
03/08/13 12:46 AM
03/08/13 12:46 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
cool. im looking foward to seeing the swap
Re: Rack and pinion swap on 84 D-150 [Re: 72d100] #1396307
03/08/13 12:51 AM
03/08/13 12:51 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
I will keep and post picture progress!
84 D150 440/727
79 /6 swb D150
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396308
03/08/13 03:26 AM
03/08/13 03:26 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Im going to do this to one of my sweptlines, swap in the newer crown vic front end. Im not sure which one I want, one has 17 inch wheels, and the other has 18 inch wheels, I will have to see if the 17's clear the 18 inchers calipers. Looks like a simple deal, nice tidy package.
Re: Rack and pinion swap on 84 D-150 [Re: cageman] #1396309
03/08/13 01:05 PM
03/08/13 01:05 PM
dogdays Offline
dogdays  Offline
I'd suggest 2002 or older, later ones used a wheel with high positive offset, like a front wheel drive car.
R.
Re: Rack and pinion swap on 84 D-150 [Re: dogdays] #1396310
03/08/13 04:22 PM
03/08/13 04:22 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
That's good though, gets the track width wider to match my truck.
Re: Rack and pinion swap on 84 D-150 [Re: cageman] #1396311
03/08/13 11:46 PM
03/08/13 11:46 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
It is my understanding the 02 and earlier ones are non rack and pinion and have smaller brakes.
The unit is designed for 34 inch wide frame rails on the 03 and newer ones. On the newer ones ya do have to run at least 16 in wheels, and they are offset to the inside.
My goal is rack and pinion steering, great brakes, lower ride height with larger diameter wheels, with the added benefit of a lighter weight unit. I found out tonight these units have a cast aluminum crossmember.
I plan on using 18 in mustang bullet wheels.
84 D150 440/727
79 /6 swb D150
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396312
03/09/13 08:59 PM
03/09/13 08:59 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Well, my search continues. The car the front suspension was under had been hit really hard on the passenger side rear, and the frame was "z'd" badly. There is a crack in thr aluminum structure.
The guy I was getting it from has a towncar (same suspension) coming in next week. He sold me the rack and pinion unit for 25 bucks!
I am looking into how much horsepower early 90s thunderbird rear end will handle. They are independent suspension and are in their own carriage. I hope somewhere in the mid 400s with some mods.....
84 D150 440/727
79 /6 swb D150
Re: Rack and pinion swap on 84 D-150 [Re: old_goat] #1396313
03/10/13 02:25 PM
03/10/13 02:25 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
that sucks about the frame. hope you find a good one. and the irs should be pretty strong if it an 8.8 center section.
