Castle nuts and cotter pin install. #139533
10/21/08 08:36 AM
10/21/08 08:36 AM
Toronto, Ont, Canada
boydsdodge Offline OP
I am wondering what the correct method is for installing castle nuts and cotter pins.
Do you tighten the nut to the spec torque and then more to line up the hole for the cotter pin?
Or?
Thanks.
Re: Castle nuts and cotter pin install. [Re: boydsdodge] #139534
10/21/08 08:50 AM
10/21/08 08:50 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you are working on front wheel bearings torque and back off.
Never have used a torque wrench on the them. Have always gone by the spin and feel method and never had one fail.
Re: Castle nuts and cotter pin install. [Re: boydsdodge] #139535
10/21/08 08:54 AM
10/21/08 08:54 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Loosen the nut and retighten a couple times and it may line up the hole for the cotter pin. I usually just tighten to align the hole. A true perfectionist would remove the nut and carefully remove a bit of the nut with a file.
Re: Castle nuts and cotter pin install. [Re: MO_PA] #139536
10/21/08 08:59 AM
10/21/08 08:59 AM
I am working on front end parts, ball joints tie rods etc..
Some books say to shim the nut, which would be like shaving it.
But if you shim with washers it will be too high covering the hole.
I was just worried I am over stressing the bolt.
Re: Castle nuts and cotter pin install. [Re: boydsdodge] #139537
10/21/08 10:26 AM
10/21/08 10:26 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Tighten it down then tighten till the hole lines up and you can get the pin in. You never want to loosen the nut to line it up.
Re: Castle nuts and cotter pin install. [Re: WILD BILL] #139538
10/21/08 11:05 AM
10/21/08 11:05 AM
MNobody Offline
MNobody  Offline
