Size of electric cooling fan(s). Amp draw? airflow?
#1395051
02/28/13 02:51 PM
02/28/13 02:51 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Guys,
Basic question is: Is there a method to sizing your electric radiator fans if you need additional or adequate cooling?
I have a 335hp non-Mopar that overheats when it's driven much below 40-50mph and the outside temps are near 80F. It's got two shrouded electric cooling fans on its radiator, with thermal switches that kick one on first, then the other as the coolant temp rises.
The airflow I feel coming off the non-OEM fans isn't what I think of as "aggressive" - the airflow hardly pushes my outstretched hand back. I recall my old car with electric fan had a heck of a push.
So I think the answer lies in installing more powerful fans. I think I could measure the diameter and the ampere draw on my existing fans (let's say 12" fan, 5amp draw) and compare that to catalog offerings (12" fan/ 9amp draw and check the wiring gauge) to get more flow...
What're your opinions?
Thank you, -Art
BTW - The only thing in the cooling system we haven't tried is borescoping the block to check for casting restrictions. Everything else we can think of about the cooling system has been scrutinized: radiator was bench tested, meets OEM spec, hoses are clear and not collapsing (the prob is only at low speed), proper bleeding, coolant fluid, added water-wetter, water pump flow all check out OK.
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Size of electric cooling fan(s). Amp draw? airflow?
[Re: 67SATisfaction]
#1395052
02/28/13 03:22 PM
02/28/13 03:22 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You have 5 amp and 9 amp fans on that car?
Check again.
Amperage draw determines to work an electric motor is doing.
You want something closer to 30 amp draw to cool an old car.
[Re: feets]
#1395053
02/28/13 04:24 PM
02/28/13 04:24 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
CFM determine how much airflow the fans will push. You will want something in the 2500 and up range depending on your needs...probably closer to the 3000 CFM range. I have a BeCool 2760 CFM dual 11" fan on my radiator with a 20 amp draw (measured) and it keeps my big block stroker at 185-190 degrees at stand still on a cool day. This is on the low end of the factory temp gauges. I don't think that everyone needs to these monster 30-40+ amp fans...in many cases that can be a 'BandAid' for a deficient cooling system or other engine issue. Lots of things can cause overheating besides not enough airflow. Not to say it's a bad idea to have extra cooling...just may not be necessary. Also say goodbye to the a factory alternator with a 30 amp+ draw. However if the motor is running cool when moving but the minute you slow down, we have overheating then it could be an airflow issue. I would look at the CFM ratings on the fans and compare to what I said above. Fan shrouds that fit tightly over the radiator also make a huge difference to make sure all the airflow is 'funneled' through the radiator. And yes, there is a huge difference between the quality of the $50 cheapo fans and the more expensive units. I would expect to pay $250-$300+ for a quality fan/shroud setup (minus the wiring/relays/etc.) Good Luck!
[Re: cjskotni]
#1395055
02/28/13 07:23 PM
02/28/13 07:23 PM
67SATisfaction
Albany, NY
Thanks all, that's great information I can use to get started.
Feets - Those amps I gave were just guessing to illustrate an example. I haven't yet measured the draw on my existing fans, but I will now so I know where things stand. cjskotni - Thanks, that's excellent "sample" information. I'll check the alternator capacity and work it into the solution.
Thanks again guys! -Art
Edit: Of course, now I see the Monster Cooling Fan thread you posted Feets, I'll go read that now...
[Re: forphorty]
#1395057
02/28/13 09:46 PM
02/28/13 09:46 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
the HHR is nice if you want a "slap it on, plug it in" fan. it comes with it's own shroud.
but I don't like the HHR fan. I like the Jeep Grand Cherokee fan. it's 19" diameter, pulls a metric crap ton of air, and can be had brand new for about $50 from the mopar dealership.
only problem with the fan, is that it's got a taper on both sides of the fan, so you'll have to fabricate your own mount to make it work, you can't just slap it up against the radiator.
OEM fans are the way to go. they're built to run 100k miles or more, and are mass produced enough that the cost is cheap compared to an aftermarket fan that cost twice as much, pulls half the amps, moves 1/4 of the air, and blows up in 15k miles.
**Photobucket sucks**
[Re: RobX4406]
#1395059
02/28/13 11:52 PM
02/28/13 11:52 PM
70Cuda383
Marysville, O-H-I-O
uh....the year with the recall for the E-fan? Let me search for it...
[Re: 70Cuda383]
#1395060
02/28/13 11:57 PM
02/28/13 11:57 PM
70Cuda383
Marysville, O-H-I-O
Looks like an early 2000s 4.7L Grand Cherokee. Rock Auto had one for an 01, 4.7L GC. but they want $177 for it.
I got mine from the dealer for $50 back in about 05 or 06
[Re: 70Cuda383]
#1395061
03/01/13 01:26 AM
03/01/13 01:26 AM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Just a thought i have two 10" fans on a 3row champion rad. for the hemi in the challenger i used two differnt sencers to have fans come on first one would not kick them on till over 210° the other was 195°that was in tested on stove in.water i wired them so come on with the key the hemi ran for bout 10-15 min idle temp would not get over 165° so i had to undo one of them is it possible that its not coming on soon enuff and the low speed just not enuff air movement?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: feets]
#1395062
03/01/13 02:13 AM
03/01/13 02:13 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Check again.
Feets is right on here....OEM fans are the only way to go....I run the famous 90's ford taurus V6 fan....awesome amount of air. Pulls 30+ amps....over 50 at start up. Google it...it is one of the most popular to use.
HHR is good too, so is Mark VI fans...
[Re: DaytonaTurbo]
#1395064
03/01/13 09:30 AM
03/01/13 09:30 AM
70Cuda383
Marysville, O-H-I-O
my personal preference, and rationale, is that mechanical fan, although effective...never shuts off. even if the clutch goes to "near idle" on the fan, you're still spinning it with the engine...all the time...when you don't need it. the nice thing about electric fans, is that you CAN get one that works, and wire them to ONLY work when you need them. the whole "ma had it right" argument that guys often spout is amusing to me. If there's "no need to change anything, the engineers had it right from the factory" then why does the same guy who makes that point have bigger brakes, ported heads, camshaft swaps, stroker cranks, stiffer T-bars, adjustable shocks....
#1395066
03/01/13 12:42 PM
03/01/13 12:42 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
nothing beats measuring things yourself like an engineer would you need to buy a small "wind speed meter" and use it to measure the average speed of the air entering your radiator. Kestrel makes extremely good ones, acceptable is the $31 LaCrosse or the $20 Eddie Bauer http://www.amazon.com/La-Crosse-Technolo...osse+wind+speedi have measured myself with the cheap LaCrosse meter and also an expensive and calibrated coal mining spec Anenometer about 3600 cubic feet per minute of airflow on a 245 HP 360 V8 at idle 570 rpm with an AC condensor in front of the radiator adding resistance and the viscous clutch 5 blade fan unlocked and slipping so that it was turning about 480 rpm when the viscous clutch locks and at higher RPM the cfm of the air moved will roughly double with doubled RPM but the power consumed by the fan will go up dramatically ... when the RPM doubles to 960 the fan will use between 4 and 8 times more horsepower ( for geeks raise to power of 2.4) as you can tell from the wimpy power of these 13.8 volt DC electric fans, which you can estimate by multiplying: volts times amps times 0.8 (efficiency) then divide by 746 to convert watts to US standard Horsepower they can not move air in volumes like a mechanical fan because their motors dont have the horsepower somewhere i have a graph of the power consumption versus RPM of the viscous clutch fan of a Chrysler 340 V8, which also showed the power consumption of the power steering and alternator. i have posted that graph on Moparts in the past, i think it is in the back of John Heywoods IC Engines book. be aware that the electric fan manufacturers are tricky in their advertising .. what they call CFM is in free air with the fan standing alone, and is not pulling through the resistance of the radiator fins or the air conditioning condensor, or in some cases additional coolers on the other hand the cooling system on factory vehicle setups are way oversized ... most are set up for towing trailers up 6 percent grades in Death Valley national park in 120+ F outside air temperatures while staying below 240 degrees F coolant temperature i have run a 200 mile long 70 mph highway cruise fuel economy test with no fan blades at all, using special NPG coolant that is only 70% the heat removal capacity of normal 50/50 ethylene glycol-water coolant, and observed no over heating
[Re: DaytonaTurbo]
#1395067
03/01/13 01:05 PM
03/01/13 01:05 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Is there any reason you can't run a factory style fan system? You know, proper mechanical fan and shroud, setup with the correct spacing. You don't hear of a lot of guys overheating with this setup.
Absolutely!! The Mopar OE system works well due to its overdesign.. In SoCal on hot days, our 525HP wedge runs fine and cool, rarely goes beyond 180...
Sounds like the block needs to be flushed out.. If plugged badly one can hang 5 fans on it and it will still overheat..
Just my $0.02..
[Re: 70Cuda383]
#1395068
03/01/13 02:41 PM
03/01/13 02:41 PM
DaytonaTurbo
Manitoba, Canada
And the problem with the fan running all the time, even with the fan clutch dragging a little is?????? Extra airflow through the engine bay, evacuating out engine heat, helping to cool headers and keep air flowing across the carb does not sound like a bad idea to me. More consistent under hood temps from constant fan flow sounds to me like something a carb is easier made to deal with, rather than fluctuating under hood temps as an electric fan cycles on/off allowing under hood temps to cycle up and down.
I read a car craft article on time where they dynoed a sb chevy with a clutch fan vs a fixed fan vs an electric. If memory serves the fixed fan lost 15hp from the electric and the clutch lost about 7 from the electric. Sounds like a lot of extra money and hassle combined with sub-par cooling in many cases, just to gain a few hp.
