What rings to use for nitrous application? #1394992
02/28/13 02:04 PM
02/28/13 02:04 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I'm putting together a 451 with some Ross pistons and about 12.25:1 compression. I'm contemplating using nitrous but am unsure about how much. I have been advised that I should avoid plasma moly rings for a nitrous application but have heard it's okay up to a 150 shot. Obviously I have heard good things about the Hellfire rings or some total seals but also heard they aren't really a maintenance free long lasting set up. This will be a street strip car and will accumulate maybe 1500 miles a year at best. What do you guys recommend for a nitrous application? I really don't want to pull the motor down every year to change rings. Is there long lasting quality that comes with the price tag on a nice set of nitrous spec'd rings? Thoughts?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: What rings to use for nitrous application? [Re: MadMopars] #1394993
02/28/13 04:24 PM
02/28/13 04:24 PM
I would put a good set of moly tops with cast seconds and standard tension oil rings and open up the ring gaps up to the maximum recommended by the ring maker you use for your NOS power levels, bigger is better when it comes to ring gap and NOS
Re: What rings to use for nitrous application? [Re: MadMopars] #1394994
02/28/13 05:39 PM
02/28/13 05:39 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
For what you are talking, you do not need any special nitrous ring package.Gap accordingly, and you'll be fine.
RIP Monte Smith
Re: What rings to use for nitrous application? [Re: CompWedgeEngines] #1394995
03/01/13 02:04 AM
03/01/13 02:04 AM
Tucson AZ,
Tucson AZ,
After researching this all afternoon, I think the I'm going to go with the Plasma Molys. They both have there pros and cons but I think for the direction I'm going the Speed pros should work for now. You guys called it. Thanks for the input.
Re: What rings to use for nitrous application? [Re: MadMopars] #1394996
03/01/13 02:22 PM
03/01/13 02:22 PM
NY
challenger451ci Offline
NY
Give Matt Hartford at Total Seal a call. I can't say enough about the level of support Matt has given me.
(623) 587-7400 x211
His email is:
matth@totalseal.com
Re: What rings to use for nitrous application? [Re: challenger451ci] #1394997
03/01/13 02:38 PM
03/01/13 02:38 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
My 451 has Mahle plasma moly's on Iconn forged pistons. The gapping instructions that came with the rings had specific instructions for nitrous, supercharged, ect. Everything I remember with the literature that came with them seemed to suggest that they were fine for Nitrous Applications. Even though I don't have any immediate plans for a nitrous system, I gapped mine per the nitrous application, with the thought that I may someday throw a mild system at it.
Re: What rings to use for nitrous application? [Re: Cab_Burge] #1394998
03/01/13 09:07 PM
03/01/13 09:07 PM
MN
hemidup Offline
hemidup  Offline
MN
I'm with Burge on this one. The n2o/supercharged engines I build use a 1/16" top steel, 1/16" conventional 2nd and 3/16" std oil and bigger is better when it come's to ring gaps.
Jerry Williams.
Re: What rings to use for nitrous application? [Re: hemidup] #1394999
03/01/13 10:49 PM
03/01/13 10:49 PM
Tucson AZ,
Tucson AZ,
Here's the next set of questions: What is the difference between Plasma Moly and Moly rings? Which one would be better? Low tension or standard tension rings? Second ring design or material preference? I'm sure I'm being overly picky but I'm here to learn.
