Re: What rings to use for nitrous application?
[Re: MadMopars]
#1394994
02/28/13 05:39 PM
02/28/13 05:39 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
For what you are talking, you do not need any special nitrous ring package.Gap accordingly, and you'll be fine. ![](/ubbthreads/images/graemlins/thumbs.gif)
RIP Monte Smith
[Re: MadMopars]
#1394996
03/01/13 02:22 PM
03/01/13 02:22 PM
Posts: 292 NY
challenger451ci
NY
After researching this all afternoon, I think the I'm going to go with the Plasma Molys. They both have there pros and cons but I think for the direction I'm going the Speed pros should work for now. You guys called it. Thanks for the input.
Give Matt Hartford at Total Seal a call. I can't say enough about the level of support Matt has given me.
(623) 587-7400 x211
His email is: matth@totalseal.com
