Re: Gen 3 Hemi Build
[Re: Racer33]
#1394732
02/28/13 12:57 PM
02/28/13 12:57 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
the eagle head flows over 300 stock and will match up better to the drag pack intake. I just got a intake from Muscle Mike and it is awesome
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Racer33]
#1394734
02/28/13 01:13 PM
02/28/13 01:13 PM
sixpackgut
Charleston
Um, that is the short version https://board.moparts.org/ubbthreads/show...&PHPSESSID=the Eagle heads are the 2009 a newer 5.7 heads I believe. There are a ton of threads on here, I suggest you start reading all of them
[Re: sixpackgut]
#1394736
03/04/13 12:29 PM
03/04/13 12:29 PM
Ray, Racer33 has dug through every single inch of gen3 HEMI info. Why is there such a limit on cam choices, Seems only Hughes really offers a good selection. Honestly I havent really dug through the cam choices, but Ive done a little, and looked through comp, Hughes, and kinda fizzled out from there
How well do the stock lifters hold up to any performance upgrades? Is that an area of possible issues?
#1394737
03/04/13 02:30 PM
03/04/13 02:30 PM
sixpackgut
Charleston
from what I understand, stock lifters are excellent. The cam choice problems could simply be that the arena for cams is similar to what the LS guys have. Ever hear someone say they run a TRex cam, ya well, I don't know what the hell that means either.
Arrington, HHP, BES and there are a few others that specialize in modern hemi stuff and they support the LX forums and they probably do more homework on the new hemi's than Comp does. This is not to say you can't call up Porter and ask him to spec a cam from Comp for a new hemi
[Re: AlexP]
#1394739
03/04/13 03:50 PM
03/04/13 03:50 PM
XE R?
Not familiar with that, sorry to be ignorant, but I havent a clue on that one.
[Re: Moparmal]
#1394745
03/04/13 11:30 PM
03/04/13 11:30 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
Here,s one..
Have you ever measured piston to valve for the SRT Max in a 6.1?
I know what my Max Plus on a 110 LSA came in at...and its damn tight..
....just wondering what the normal SRT MAX 112 LSA P-V measures up as?
I've not measured that cam, but I have measured a 219/223 in a 5.7/6.1 and a 223/227 in a 6.1.
Both had at least .040 PTV.
[Re: Racer33]
#1394748
03/05/13 12:22 PM
03/05/13 12:22 PM
Guitar Jones
You should be able to remove them.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Racer33]
#1394750
03/05/13 12:38 PM
03/05/13 12:38 PM
Guitar Jones
