Big block Chevy rods with widest bottom-end width? #1394363
02/27/13 11:28 AM
02/27/13 11:28 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
So it appears that Eagle has discontinued their 6.700" connecting rod with the Chrysler width (1.007" BE)
Of the various companies that make a 6.700" big block Chevy rod (2.200 big end, .990 pin) - which ones have the widest bottom ends?
Though one is led to believe that large side clearances at the rods are not a big deal, psychologically I'd prefer to keep them a bit tighter and not add .020" if I have to.
Thanks in advance
Re: Big block Chevy rods with widest bottom-end width? [Re: YYZ] #1394364
02/27/13 01:11 PM
02/27/13 01:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I heard Manley had what you`re lookin 4............
Re: Big block Chevy rods with widest bottom-end width? [Re: YYZ] #1394365
02/27/13 04:46 PM
02/27/13 04:46 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Thanks in advance
We built an engine that made over 700hp wit hthe eagle BBC spec big end , it didn't seem to be an issue .
I'm using K1's , I don't remember the big end width though .
Re: Big block Chevy rods with widest bottom-end width? [Re: JohnRR] #1394366
02/27/13 09:32 PM
02/27/13 09:32 PM
YYZ Offline OP
YYZ  Offline OP
Any effect on oil pressure at idle, having the narrower rod ends?
Re: Big block Chevy rods with widest bottom-end width? [Re: Thumperdart] #1394367
02/27/13 11:32 PM
02/27/13 11:32 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
"had" being the operative word here. they "had" a 6.765 long, chrysler width sportsmaster with the .990" pin but discontinued them some time ago. to make matters worse they discontinued the bb chevy sportsmaster rod as well. now afaik the only choices from manley for a 6.7 rod would be the imported chevy H beam or the pro series I beam both of which will have the chevy width
i don't know that they ever had a 6.7 long rod with the chrysler width
if someone knows different please feel free to correct me
Re: Big block Chevy rods with widest bottom-end width? [Re: jamesc] #1394368
02/27/13 11:49 PM
02/27/13 11:49 PM
YYZ Offline OP
YYZ  Offline OP
Eagle had a 6.700 rod with 2.200/.990 CRS6700C3D but it was discontinued 2 years ago.
That doesn't stop some places from showing stock, or continuing to list them on eBay
Re: Big block Chevy rods with widest bottom-end width? [Re: YYZ] #1394369
02/28/13 12:07 AM
02/28/13 12:07 AM
jamesc Offline
jamesc  Offline
afaik you're not going to find 6.7 long, 2.2 throw chrysler width rods from anyone. i "think" eagle has a 6.76 long rod with the other dimensions you mentioned. if you're asking about who has the widest chevy width rod i wouldn't bother as now you're into manufacturing tolerances.
i'd say if you need a 6.7, 2.2, .990 pin rod you have two choices either custom rods to get a wider BE or chevy rods with the standard .990 BE width. there are plenty of engines out there with a lot of side clearance and no one likes it but i can't remember anyone having real issues doing it. as for oil control imho the bearing clearances are what primarily dictate that, of course pressure and viscosity come into play as well.
Re: Big block Chevy rods with widest bottom-end width? [Re: YYZ] #1394370
02/28/13 01:21 AM
02/28/13 01:21 AM
Cab_Burge Online work
Cab_Burge  Online Work
None at all I've run motors with .026 rod side clearances with .0033 bearing clearances and ran a different motor with the same bearing clearances, oil pump and oil pressure with rods that had .050 side clearances, no noticeable diffirences on the street or at the track The bearing clearances and oil pump along with the heat and viscotity(SP?) of the oil deteremines the oil pressure and volume of oil flowed through the motor, not just the rod side clearances I use to worry about the wide side clearances until I saw more motors hurt with to tight(less than .010) rod side clearances than those with way to much side clearances, above .028
Re: Big block Chevy rods with widest bottom-end width? [Re: YYZ] #1394371
02/28/13 03:39 PM
02/28/13 03:39 PM
JohnRR Offline
JohnRR  Offline
not that I could tell, the block had modified oil passages , opened up to create more flow to crank and we ran both a hi volume and a stock pump that was ported by member streetwise and it had a milodon adjustable regulator and the motor had more than enough oil pressure. Oil pressure escaping is regulated more by the bearing clearance and less by the width of the bearing shell itself .... I think ???
There are thousands of engines running with BBC width rods ...
Re: Big block Chevy rods with widest bottom-end width? [Re: YYZ] #1394372
02/28/13 03:40 PM
02/28/13 03:40 PM
JohnRR Offline
JohnRR  Offline
There are others selling this type of rod for similar money . Contact member Performance_only , he'll get you a set of GOOD rods for not a lot of money.
Re: Big block Chevy rods with widest bottom-end width? [Re: JohnRR] #1394373
02/28/13 07:34 PM
02/28/13 07:34 PM
CDoering Offline
CDoering  Offline
I asked a similar question a few months ago. I'm not aware of anyone selling a 6.700 long rod with the 2.2 journals and the Mopar width.
It would be great if Performance Only had some available. Eagle still makes the 6.76 length rod with the 2.2 journal and 1.007 width but they were on back order a couple of months ago. Molnar is also making a 6.76, 6.86 and 7.1 rod with the 2.2 journal and 1.007 width.
Re: Big block Chevy rods with widest bottom-end width? [Re: CDoering] #1394374
02/28/13 07:55 PM
02/28/13 07:55 PM
JohnRR Offline
JohnRR  Offline
Molnar was the owner of K1 , went on his own after things went in the wrong direction after he sold the company . This is the rod I would be buying .
Re: Big block Chevy rods with widest bottom-end width? [Re: JohnRR] #1394375
02/28/13 09:43 PM
02/28/13 09:43 PM
YYZ Offline OP
YYZ  Offline OP
Cool - thanks for the advice. Part of the search is because I have a beautiful 3.9 stroke American-made MP crank, fully indexed and the 6.700" rods will be perfect for a zero-deck motor with my pistons (and block correction)
Re: Big block Chevy rods with widest bottom-end width? [Re: YYZ] #1394376
02/28/13 10:51 PM
02/28/13 10:51 PM
CDoering Offline
CDoering  Offline
I just received a set of the Molnar 6.7 rods yesterday for use with a 3.9 stroke crank. I already had pistons when I found out that Eagle had stopped making the 6.7 rod with the Mopar big end. Lots of places still list them on line as they haven't updated their web sites in a long time.
