Re: home ported heads [Re: bwhackd34] #1394270
02/28/13 06:14 PM
02/28/13 06:14 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I learned years ago to pick one task/area to fix and do it for each port on both sets of heads before going to the next task. That helps keep us novices from becoming over-zealous on one port or cylinder before making all the same moves on the other ones.
I have no idea if it's good or bad - but after porting mine, I took them to a buddy with a flow bench to "check" them. I had a 3 cfm spread between best and worst ports. Like I said, I have no idea if that's fairly close or really messed up, but that's how they are.
Re: home ported heads [Re: poboyengineering] #1394271
02/28/13 08:12 PM
02/28/13 08:12 PM
Ohio
moparjoe360.4 Offline
Ohio
the swirl port thing sort of worries me..it looks like they take up a lot of room, and the serious heads dont have them.
Are you talking about the rotator on the exaust valve? If you are it will cause problems even with a small performance cam.... I have a head with a hole in it to prove it. One of my valves broke at the retainer (from coil bind?)fell down in the cyl. bent the rod n punched a stem sized hole in the head.
Re: home ported heads [Re: poboyengineering] #1394272
03/01/13 02:08 AM
03/01/13 02:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't do an entire port all at one time. I will start with gasket matching all the ports, then work on the bowl of the ports, etc to keep them all about the same. I use dividers to check consistency. I will usually do just a part of the port then duplicate that on the other ports, then go back and do a bit more, and repeat.
Re: home ported heads [Re: 451Mopar] #1394273
03/01/13 03:23 AM
03/01/13 03:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I learned how to do valve jobs in my high school auto class but that was just basic valve jobs. Then I learned alot more of the porting and all on my own as my brother bought his own valve grinding tools when he had his own shop. I also found out you always spend way more time porting heads then you think you will spend. These 906 heads here I did my own porting on and I installed the 2.14 and 1.81 valves myself with my brothers machine shop valve grinding tools. We had the tools to cut the guides down for the smaller seals when going to dual springs and even had the tools to knurl valve guides. These are the 906's I used on the mild 440 I had in my 63 for a few years. I opened them up and put the 2.14 and 1.81 valves in them and then worked and blended the bowls along with the rest of the porting. I know I spent at least 40 hrs in the heads and I found out that after I had back surgery there was no way I could port heads any more. Just trying to bend over the heads for a few minutes was impossible with my back problems. This was the last set I ever ported as it was right before I fell and had back surgery. I never flowed them as we had no bench. I just did them as I had learned over the years but I was by no means a profesional head porter. I did many stock valve jobs over the years on friends and customers cars but most were just stock daily drivers. Just mine and my hot rod buddies were the ones I ported myself. I enjoyed doing it but never flowed any to know how good they were. I only knew what worked when I put the heads back on the cars and they went faster. So when I bought my EZ heads I had Dwayne Porter do some of his magic on them. He is a pro and there is no way I could be anywhere as good as him as he has done thousands more heads then me and flows them so he knows what works. I always enjoyed the pride of building my own engines and doing all the work myself but I was a profesioal auto repair tech for my living with my porting and hot rod skills as my hobby. I cant thank Dwayne porter enough for the great job he did on my EZ heads for me. He is a profesional head porter and knows just where to port and what works the best. Here is a pic of the 906's I put the 2.14 and 1.81 valves in and used on my mild 440. Ron
Re: home ported heads [Re: 383man] #1394274
03/01/13 10:01 AM
03/01/13 10:01 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I hear you Ron! I have a flow bench and valve grinding equipment here at the house... I just send all my heads to Dwayne these days. He has done 6 to 10 sets of heads in the last 5 years and I have never had one issue with any of them.
To the OP, there is something to doing it yourself but tread lightly it is easy to waste your time and make junk. Less is more sometimes, hard to have positive results without a bench.
Re: home ported heads [Re: scatpacktom] #1394275
03/01/13 01:02 PM
03/01/13 01:02 PM
Glendora, CA
MYBD318 Offline
MYBD318  Offline
Glendora, CA
Still a teen just a 416
Re: home ported heads [Re: MYBD318] #1394276
03/01/13 02:07 PM
03/01/13 02:07 PM
dogdays Offline
dogdays  Offline
Talking about bending over a head, I find my best results are from sitting on a tall stool with the head on a bench even with the fattest part of my biceps. I don't like the control I get standing up, bending over the bench.
R.
Re: home ported heads [Re: poboyengineering] #1394277
03/01/13 05:22 PM
03/01/13 05:22 PM
pennsylvania
poboyengineering Offline OP
pennsylvania
ive had some conversations with john cadamore (thanks john!) and the subject of putting a 2.05 intake into the 308 heads came up. anyone done this? what were the results?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: home ported heads [Re: moparjoe360.4] #1394278
03/01/13 05:34 PM
03/01/13 05:34 PM
pennsylvania
pennsylvania
ive already eliminated the rotators, mostly due to the weight. there is a "wing" thing in the intake to steer the air for swirl. im thinking cutting this back to about 1/4 to 3/8 inch just to move the air around the valve guide.
Re: home ported heads [Re: poboyengineering] #1394279
03/01/13 07:49 PM
03/01/13 07:49 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Dunno if I'd be so daring to do that just yet............
there's a LOT of racers that have upgraded thier cars to those heads. Don't think the class/production guys can do any mods but I'm sure there's someone out there that has put them thru a flowtest since they are a "best production", better than a J or X head. Ask here or on YellowBullet.
Re: home ported heads [Re: Dean_Kuzluzski] #1394280
03/02/13 09:25 AM
03/02/13 09:25 AM
pennsylvania
pennsylvania
i guess its a good thing ive got unmolested spares then!
