OILING R3 BLOCK #1394197
02/27/13 01:17 AM
02/27/13 01:17 AM
ohio
dragon Offline OP
dragon  Offline OP
ohio
do all R3 blocks oil the same way i am talking about the 48 degree and the 59 degree are the passages the same etc ? THANKS
Re: OILING R3 BLOCK [Re: dragon] #1394198
02/27/13 02:22 AM
02/27/13 02:22 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The main oil galleys by the lifters are the same on 48 and 59. On a 59 you can actually see the oil galley through the lifter bores just like a stock block. On a 48 you cannot. That is why you have to drill the oil feed holes from the oil galley to the lifter bores on virgin blocks.
Leon
