broadcast sheet question? #1394097
02/26/13 10:36 PM
02/26/13 10:36 PM
Iowa
barrycuda Offline OP
super street
super street
Iowa
I have a 1970 cuda built on Oct 8 (A08) and the broadcast sheet is hard to read because it is printed on the 1969 paper. The option layout is different on the two. It helps if I use a bs from another 1970 car to make sure where the option locations are. I was wondering if this is common for all of the 1970 cars that were built in the Fall of 69?
Re: broadcast sheet question? [Re: barrycuda] #1394098
02/26/13 11:00 PM
02/26/13 11:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It is very common for the sheets found in the seats. The trim code was in the same place on both versions of the sheet, so the trim shop was a great place to use up the leftover stock.
Re: broadcast sheet question? [Re: Alaskan_TA] #1394099
02/26/13 11:27 PM
02/26/13 11:27 PM
Iowa
super street
super street
Iowa
Thanks Barry, that makes sense.
Re: broadcast sheet question? [Re: barrycuda] #1394100
02/26/13 11:57 PM
02/26/13 11:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Anytime.
Also, the scheduled production date is the date they hoped to build the car, but there is no way to know if the car was built that day if your Mylar door sticker shows the same month.
Lots of cars show an earlier or later month on the door sticker, so at least with those we can tell if they were built early or late.
Re: broadcast sheet question? [Re: Alaskan_TA] #1394101
02/27/13 02:28 AM
02/27/13 02:28 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Barry L., Does your 'Cuda have M31 - "belt mouldings" both on the fender tag & the car?
Re: broadcast sheet question? [Re: 6bblgt] #1394102
02/27/13 08:14 AM
02/27/13 08:14 AM
Iowa
super street
super street
Iowa
Dan, I will check when I get home later today.
Re: broadcast sheet question? [Re: barrycuda] #1394103
02/27/13 11:04 AM
02/27/13 11:04 AM
tboomer Offline
tboomer  Offline
Barry...I think I have some pics of your car the night you took it home...Man!! That nigh was a mess!
Re: broadcast sheet question? [Re: 6bblgt] #1394104
02/27/13 07:23 PM
02/27/13 07:23 PM
Iowa
super street
super street
Iowa
Yes, M31 is on the fender tag, bs and the car. The "belt moulding" is the chrome on top of the doors and qtr panels, right?
Re: broadcast sheet question? [Re: tboomer] #1394105
02/27/13 07:39 PM
02/27/13 07:39 PM
Iowa
super street
super street
Iowa
Hi Ted!! it has been a while. Are you referring to this night??Its kind of hard to forget that night! I was on cloud nine for a long time after getting my cuda'. That was in June of 2002, man time fly's. How have you been?
Re: broadcast sheet question? [Re: barrycuda] #1394106
02/28/13 08:53 AM
02/28/13 08:53 AM
tboomer Offline
tboomer  Offline
My wife wasn't too happy about that! Can't believe it was almost 11 years ago. You will have to come to Mopar Max III at Cedar Falls in Sept. and put your car into the show!
