971 oil pan with 4.15 stroke...will it clear ???? #1393384
02/25/13 03:00 PM
02/25/13 03:00 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
I have a Moroso 7 qt pan ( 971 oem pan )that is for sale and someone asked if it would clear the stroker rods and counterweights at the front wher the pan is kinda low. Has anyone used a 971 pan on a 440 with 4.15 stroke ? The Moroso pan I have a just a modified 971 pan. Thanks in advance for any help..
Re: 971 oil pan with 4.15 stroke...will it clear ???? [Re: THESHAKERPROJECT] #1393385
02/25/13 03:23 PM
02/25/13 03:23 PM
It has the hump in the front of the pan to clear the stock Mopar windage tray which will fit with most 4.15 stroker crank and rods
