Nitrous & bottle question. #1393157
02/24/13 11:11 PM
02/24/13 11:11 PM
right between milan dragway & ...
Flite_727 Offline OP
I have a 10lb. bottle that has been sitting dormant for approx. 8 yrs. it is still over 75% full. I recently went to test some solenoids & when I opened the bottle there was some slight leakage coming right out the top center of the handle around the nut.
Question 1) is there any way to save the no2 in the bottle? Do any dealers buy back unused no2?
Question 2) are there rebuild kits available for bottle valves? This is an older top gun bottle, with a standard flow valve. I would imagine its just an o ring that is leaking.
Thanks-
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Nitrous & bottle question. [Re: Flite_727] #1393158
02/25/13 12:25 AM
02/25/13 12:25 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
The valves aren't rebuildable unfortunately....your best bet would be to buy a new valve, see if you can find a nitrous dealer who has a pump and capture the gas, install the new valve, and recharge.
Re: Nitrous & bottle question. [Re: Flite_727] #1393159
02/25/13 01:06 AM
02/25/13 01:06 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Back seating the valve lot's of time will stop the leak.
