Top Fuel Hemi Cranks #1392514
02/23/13 05:45 PM
02/23/13 05:45 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
My friend has a couple of these laying around in his garage. I can't seem to find any info on them. I have heard that if they check out ok they can be reused. Anyone have any insight?
Thanks,
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: Top Fuel Hemi Cranks [Re: Jambbii] #1392515
02/23/13 06:42 PM
02/23/13 06:42 PM
yarnell,az
mopacltd Online content
mopacltd  Online Content
yarnell,az
Got one in my Colt. Had it turned down to Std. 440 journals (rod & main) and all seems to be just fine.
Re: Top Fuel Hemi Cranks [Re: Jambbii] #1392516
02/23/13 07:17 PM
02/23/13 07:17 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Usually you can't put a damper on them and there is no place to bolt a flex plate
Re: Top Fuel Hemi Cranks [Re: joshking440] #1392517
02/23/13 07:21 PM
02/23/13 07:21 PM
yarnell,az
yarnell,az
Josh, you are correct. I needed to index and rekey the crank.
Re: Top Fuel Hemi Cranks [Re: mopacltd] #1392518
02/23/13 07:24 PM
02/23/13 07:24 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Can be problems many do not have any register ring for converter. clearances for rods .003plus mains .005 plus
home of the
Sox and Martin Hemi Duster
Re: Top Fuel Hemi Cranks [Re: HEMIFRED] #1392519
02/23/13 07:25 PM
02/23/13 07:25 PM
yarnell,az
yarnell,az
That was all taken care of with the machine work on my crank, Fred.
Re: Top Fuel Hemi Cranks [Re: mopacltd] #1392520
02/23/13 07:45 PM
02/23/13 07:45 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
Thanks for the replies. It will be free so I am not sure if it would be worth the trouble.
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Top Fuel Hemi Cranks [Re: Jambbii] #1392521
02/23/13 07:50 PM
02/23/13 07:50 PM
yarnell,az
yarnell,az
If you don't use it. Let me know, I may be interested.
Re: Top Fuel Hemi Cranks [Re: mopacltd] #1392522
02/23/13 08:31 PM
02/23/13 08:31 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I ended up with a Bryant 4.5 stroke from some buying & selling years ago.I used it in my blown hemi for 10 years before I hurt it and bought a new rotating assembly.Cut it 10/10 and installed a converter ring.It's back on the shelf with nose damage
It had some minor cracks in it when I first obtained it and was told if I'm under 2500 HP that it would be fine.I never went over 800HP with it
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Top Fuel Hemi Cranks [Re: hemi-itis] #1392523
02/24/13 12:41 AM
02/24/13 12:41 AM
I've bought and used them, the crankshaft flywheel flanges are a little thicker than the stock Mopar street cranks are but it doesn't seem to be a big deal. Kieth Black use to sell the adapter rings to push into the back of the cranks to get a register for the flexplates to center off of, that worked well
Re: Top Fuel Hemi Cranks [Re: Cab_Burge] #1392524
02/24/13 02:49 AM
02/24/13 02:49 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
In the early days of stroker motors for a bb you had to get the journals spray welded and offset ground to make a crank.
I remember being at the mopar nationals when it was still at Indy. They were bringing in a few pallets of used top fuel cranks. These were high end heavy pieces that had cracks in them that were not seen by eye; and were no longer suitable for top fuel. They were all gone in about an hour for about $150-200 each. The word then was they were plenty strong for whatever you could ever do to them NA or even blown to about 2000 hp. I was told they were very heavy and would take a fair amount of work be useable.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Top Fuel Hemi Cranks [Re: Cab_Burge] #1392525
02/24/13 03:02 AM
02/24/13 03:02 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Pics of the adapter ring from Keith Black.
Re: Top Fuel Hemi Cranks [Re: hemi-itis] #1392526
02/24/13 11:53 AM
02/24/13 11:53 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I watched a friend go into the wall at 1000' in his car because the "cracked but good for under 2500hp" crank exploded taking some of the block out thru the wheel well and the right front tire off the rim in the middle of 3rd gear. The engine made under 900hp on dyno runs and aside from the dributor cap and wires there was nothing usable left.
If it's tested and shows cracked there is nothing but opinion about what it can take or when it will let go. IMO I'll never use them.
Re: Top Fuel Hemi Cranks [Re: moper] #1392527
02/24/13 02:04 PM
02/24/13 02:04 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Does KB still sell those adapter rings ? I just bought a new fuel crank from Bryant have a year left on my flex plate ,. ATI sells flex plates to fit these cranks but would rather buy one when I have to .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Top Fuel Hemi Cranks [Re: moper] #1392528
02/24/13 02:04 PM
02/24/13 02:04 PM
Mesa , Az
Jambbii Offline OP
Jambbii  Offline OP
Mesa , Az
I might be knocking on the wall of 2500. I can get everything checked out for free and have a choice of a bryant crank and a couple other brands. I will have to check out that adapter ring.
70 Challenger
12 Durango R/T
18 Power Wagon
67 A100
Re: Top Fuel Hemi Cranks [Re: Jambbii] #1392529
02/24/13 03:59 PM
02/24/13 03:59 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
I used mine for heavy metal donation
Re: Top Fuel Hemi Cranks [Re: go green] #1392530
02/24/13 07:13 PM
02/24/13 07:13 PM
Probally, call them at 562-869-1518 and see
Re: Top Fuel Hemi Cranks [Re: Jambbii] #1392531
02/24/13 10:40 PM
02/24/13 10:40 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
This was a friends motor that had one of those "should be good for 2000 horsepower" used fuel cranks. His motor made about 800 horsepower. This put the car into the wall at about 1/2 track. It wasn't pretty!!!
Re: Top Fuel Hemi Cranks [Re: mrrandyj] #1392532
02/25/13 12:23 AM
02/25/13 12:23 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
If a Top Fuel team is selling a crank (or anything for that matter), 99.9% of the time it's not worth having.....
If you can't handle the truth, you're living a lie.......
Re: Top Fuel Hemi Cranks [Re: Big Squeeze] #1392533
02/25/13 01:50 AM
02/25/13 01:50 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Top Fuel cars change the crank every 10 runs. Most all the time the cranks that are pulled out have hairline cracks. Some are in spots that can be welded. Long run probally easier to buy a good aftermarket steel crank.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
