Trying to decide which cam to use before I put the motor back in my car. I tore it down to swap in a set of 69 pistons which bumped compression just over a point. That being said, combo is listed below. Give me your thoughts on which cam to put in.
1973 GTX @ 3550lbs - Driver weight
440 with Standard Bore and Stroke:
9.25:1 compression cast pistons
906 heads w/ 2.14 / 1.81 valves and template porting
M1 intake currently but may switch to Tunnel Ram...
Holley 850
1.5 Rockers
1 7/8 Headers
3500 stall JW converter
4:56 Gears w/ 30" tires
12.50s @ 107 was about typical on a good day before piston swap.
Cam Card pictured is for the Hughes and pencil marks are for the MP 296/557, disregard valve lash, MP was listed as cold setting...
Thoughts?
When I went from the 292/509 to the 296/557 with the 8:1 compression I gained nothing FWIW...
