There is no specific torque value from the factory, just tight. It' not like rod bolt or a main cap on a engine.
The size of the bolt determines the torque value to stretch the bolt. I have memorized the torque values just by the diameter and thread pitch. I rarely use a torque wrench any more on stuff like your working on because I can feel the fastener stretch. Same with engine bolts, I bet I can get them within 5ftlbs just by feel.
You just want those bolts tight with a 1/2 drive ratchet sized tool.
Here's guide to torque values.
web page
