70 RR Column Interlock? #1390566
02/19/13 09:31 PM
02/19/13 09:31 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I am in the middle ( or somewhere in there,,,) of resto on my 70 RR. 383 4sp. I am assuming it is suppose to have colum interlock... but it seems to be missing from my boxes of parts.. I have read they are often removed...?
1st.... what is the funtion and do I need it...
Looks like I can get the complete kit for about $250....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR Column Interlock? [Re: JMCFAN] #1390567
02/19/13 09:46 PM
02/19/13 09:46 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
What is it's function: It does not allow the key to be removed from the ignition switch until the transmission is selected to Reverse.
Do I need it: That depends on your level of restoration.
Most people took them off when the car was relativly new. They are a pain in the butt. 1970 A230 3 speed manual transmissions are easier to deal with then the A833 4 speed reverse.
That being said, if your restoration is a complete original restoration, then you should use it.
Re: 70 RR Column Interlock? [Re: cudaized] #1390568
02/19/13 09:53 PM
02/19/13 09:53 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thats the problem... its ..once you start... I don where to draw the line..
Re: 70 RR Column Interlock? [Re: JMCFAN] #1390569
02/19/13 09:58 PM
02/19/13 09:58 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
I have it installed on both of my manual shift 1970 `cudas.
The 3 speed, works as it should.
The 4 speed, I have it partially disconnected.
I say install it. If you decide that you don't like the application, just disconnect the steering column to torque shaft section.
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: 70 RR Column Interlock? [Re: cudaized] #1390570
02/21/13 03:29 PM
02/21/13 03:29 PM
Orlando
JAG_mopar Offline
JAG_mopar  Offline
Orlando
If anyone has any extra parts I could use the same for my 70 convert
JAG
Re: 70 RR Column Interlock? [Re: JAG_mopar] #1390571
02/21/13 04:26 PM
02/21/13 04:26 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Re: 70 RR Column Interlock? [Re: JMCFAN] #1390572
02/21/13 05:27 PM
02/21/13 05:27 PM
Orlando
JAG_mopar Offline
JAG_mopar  Offline
Orlando
thanks JMC I did not realize they made them.
JAG
Re: 70 RR Column Interlock? [Re: JAG_mopar] #1390573
02/21/13 11:35 PM
02/21/13 11:35 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
JAG
no prob... not cheap... but available...
