Cam to timing chain spec's #1390454
02/19/13 05:22 PM
02/19/13 05:22 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
If you're using one of those cam bearing/buttons.. what is the clearance spec between the bearing and and the timing chain cover?
Re: Cam to timing chain spec's [Re: Jeepmon] #1390455
02/19/13 07:28 PM
02/19/13 07:28 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
A roller cam is more critical for tolerance, than a solid flat or hydraulic. Becuase of the bronze dizzy shaft. I try to set mine under 3 thou. Make sure what ever you are setting with, that the timing cover does not flex.
Re: Cam to timing chain spec's [Re: Jeepmon] #1390456
02/19/13 07:54 PM
02/19/13 07:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My rollerized Isky button just touches the stock cover.............
Re: Cam to timing chain spec's [Re: Jeepmon] #1390457
02/19/13 08:08 PM
02/19/13 08:08 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
FYI. There is NOT enough clearance in the oil pump to allow one of those little bearings to pass through, if it comes out/loose and gets into the oil pan.
If you like drag racing, support your local track.
Re: Cam to timing chain spec's [Re: Jeepmon] #1390458
02/19/13 11:08 PM
02/19/13 11:08 PM
I like to see .005 max cold before putting any tension on the camshaft, IE no pushrods to the rocker arms
Re: Cam to timing chain spec's [Re: Cab_Burge] #1390459
02/20/13 02:57 AM
02/20/13 02:57 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks guys.. I just wanted to make sure I had it right.. and it sounds like I do..
