big block rockers #139007
10/20/08 10:47 AM
10/20/08 10:47 AM
West Tennessee
rbstroker Offline OP
West Tennessee
I have a set of big block Harland Sharp roller rocker arms. Can these be used with stock Mopar shafts or do I need Harland Sharp ones?
This is the land of the free because of the brave
Re: big block rockers [Re: rbstroker] #139008
10/20/08 12:18 PM
10/20/08 12:18 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You need Harland shafts. The shafts Harland uses are much harder ( hard chromed) than the stock shafts, as well as have 2 oil holes in them. You are using roller bearing now, so hence the need for the change.
RIP Monte Smith
