How much torque will a stock Dana handle? #1389362
02/17/13 11:05 PM
02/17/13 11:05 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Will a stock Dana 60 handle 670 pounds of torque without any issues? Any suggested upgrades? Original rear end in 69 GTX.
Re: How much torque will a stock Dana handle? [Re: frank] #1389363
02/17/13 11:19 PM
02/17/13 11:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Should be fine. is it clutch type sure grip??
I used to replace one of the flat sets of clutches for an extra concaved for more pressure!
Re: How much torque will a stock Dana handle? [Re: frank] #1389364
02/17/13 11:19 PM
02/17/13 11:19 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Are you planning on trying to hook on a prepped surface with sticky tires? If that is a yes I'd be worried about those 23 spline axles. I'd give Dr. Diff a call and get a Power-lock rebuild kit with 35 spline spider gears and some 35 spline axles coming.
Re: How much torque will a stock Dana handle? [Re: Jeremiah] #1389365
02/17/13 11:49 PM
02/17/13 11:49 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If it an automatic OK, or 4 speed with street tires, still OK..
Slicks, and 4 speed ... need axles replaced.
