thinking of getting '75 D100-are windshields available? #1389351
02/17/13 11:03 PM
02/17/13 11:03 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Looking at a '75 D100 shortbed on my local craigslist. One major problem is the windshield has a big crack down it. I'm new to mopar trucks, does anyone make a new windshield for it, or would it be a matter of finding one?
Re: thinking of getting '75 D100-are windshields available? [Re: Exit1965] #1389352
02/17/13 11:38 PM
02/17/13 11:38 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
New ones are readily available. About $150 installed around here. If it needs a gasket its typically $60 more.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: thinking of getting '75 D100-are windshields available? [Re: hp383] #1389353
02/18/13 01:02 AM
02/18/13 01:02 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thanks!
Re: thinking of getting '75 D100-are windshields available? [Re: Exit1965] #1389354
02/18/13 11:51 PM
02/18/13 11:51 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
The windshield should be the least of your worries in finding parts.
Pretty sure it is the same glass '72-'93.
It takes gasoline to interest me.
Re: thinking of getting '75 D100-are windshields available? [Re: VL21] #1389355
02/19/13 04:27 AM
02/19/13 04:27 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Parts aren't that hard to find. Did you consider it could be a running driving truck with a crack rite in his sight making it illegal to drive
Re: thinking of getting '75 D100-are windshields available? [Re: VL21] #1389356
02/19/13 10:48 AM
02/19/13 10:48 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
VL21 is correct. You should be able to find a "windscreen" (the British term!) with no peoblem. Just takes money!
Re: thinking of getting '75 D100-are windshields available? [Re: bigblock340power] #1389357
02/20/13 09:46 PM
02/20/13 09:46 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
not trying to steal the thread but how bad is switching from a sliding back glass to a solid back glass and would glass places be able to get them?
Re: thinking of getting '75 D100-are windshields available? [Re: 72d100] #1389358
02/20/13 11:39 PM
02/20/13 11:39 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Back window is CAKE to swap. easiest with 2 people but can be done with one. Just need a screwdriver for removal and string for install
Re: thinking of getting '75 D100-are windshields available? [Re: 76dodgeboy] #1389359
02/21/13 11:41 PM
02/21/13 11:41 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
is the back window the same 72-93. i feel like they changed somewhere in there
Re: thinking of getting '75 D100-are windshields available? [Re: 72d100] #1389360
02/22/13 12:16 AM
02/22/13 12:16 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Supposedly they did but I had an 80s window in my 73
Re: thinking of getting '75 D100-are windshields available? [Re: 76dodgeboy] #1389361
02/22/13 03:33 AM
02/22/13 03:33 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
The rear sliders had a design change from the earlier trucks to the later. But they will all interchange. As far as the flat glass, I think they were all the same. Some have said the thickness of the glass, be it windshield, door, or rear got thinner on the later trucks, but that is unconfirmed to my knowledge.
If you remove and plan to reuse a slider, be sure to save the gasket. Last I knew there were no suppliers for replacements.
