Mopar Electrical Connectors Website
#1389260
02/17/13 09:35 PM
02/17/13 09:35 PM
Posts: 183 Charleston, SC
bronco9588
Charleston, SC
Anybody have a recommended source for pigtails and new electrical connectors? I have a 1973 charger and would like to replace some of the connectors.
'73 Charger Petty Blue, Black Vinyl, and Gill Slits
727 torque-flight
400 BB Chrysler
8 3/4 rear
Re: Mopar Electrical Connectors Website
[Re: bronco9588]
#1389261
02/17/13 10:17 PM
02/17/13 10:17 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
When I updated my Challenger's wiring harness I got most of the stuff I needed from here. http://terminalsupplyco.com/products/prod_catalog_pdf.aspx That was three years ago or so. Nice people to talk to. And for a big industrial looking catalog they seemed more than happy to help the hobbyist with small orders. Had pretty much everything my car needed for the stock style wiring.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: 68_CONV_300]
#1389263
02/18/13 12:39 AM
02/18/13 12:39 AM
bronco9588
Charleston, SC
how about the 8 wire connectors into the steering column?
727 torque-flight
400 BB Chrysler
8 3/4 rear
[Re: bronco9588]
#1389264
02/18/13 12:50 AM
02/18/13 12:50 AM
Michael Ecks
Columbus, GA
Not sure, but I think the steering column connector style is called Molex. Page 75 on terminal supply's catalog. If it is molex they have the pin connectors, don't see the housing though. If your housing isn't reusable call terminal supply and I bet they can find one for you if they are still made.
[Re: Michael Ecks]
#1389265
02/18/13 06:24 PM
02/18/13 06:24 PM
Posts: 1,822 Colorado
denfireguy
Colorado
It is Molex style but not a genuine Molex. A new connector comes with a replacement ignition switch if you can find one of those. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1389266
02/18/13 06:33 PM
02/18/13 06:33 PM
denfireguy
Colorado
Column side connector with switch: http://www.ebay.com/itm/New-Standard-Ign...813&vxp=mtrThe other end is part of the pricey dash harness. Evans may have the connectors but he only sells harnesses through Year One.
[Re: 1_WILD_RT]
#1389268
02/20/13 12:41 AM
02/20/13 12:41 AM
denfireguy
Colorado
You are right. Got them confused.
[Re: 2abodymcodes]
#1389271
03/07/13 12:21 PM
03/07/13 12:21 PM
bronco9588
Charleston, SC
I think i am going to start with the steering column restoration and get the new ignition and turn signal harnesses from rock auto. I would love to find the 8 pin male connectors, but will probably be replacing with high amp connectors. As far as all the other connectors in the car, did Chrysler use 56 connectors for things like the headlight switch connector? I would like to save some of the original stuff as it is very expensive .
727 torque-flight
400 BB Chrysler
8 3/4 rear
[Re: bronco9588]
#1389272
03/08/13 01:26 PM
03/08/13 01:26 PM
bronco9588
Charleston, SC
Bump on the 56 style connectors?
727 torque-flight
400 BB Chrysler
8 3/4 rear
[Re: Michael Ecks]
#1389275
03/11/13 11:07 PM
03/11/13 11:07 PM
bronco9588
Charleston, SC
The power windows use this stump and slotted sleeve connector. What type of connectors are these?
727 torque-flight
400 BB Chrysler
8 3/4 rear
