Post deleted by moparts #1389025
02/17/13 02:01 PM
02/17/13 02:01 PM
Anonymous OP
Anonymous OP
Re: Is there a PROBLEM Running 604 Aluminum Hemi on Street? #1389026
02/17/13 02:13 PM
02/17/13 02:13 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
All you need is a good radiator. There is guys with more power than that out running around.
Re: Is there a PROBLEM Running 604 Aluminum Hemi on Street? #1389027
02/17/13 02:21 PM
02/17/13 02:21 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
you need to tailor the build to that use. no way the 1180 hp that my 604 combo has would work. a different cam and compression ratio change arethe minimum needed
home of the
Sox and Martin Hemi Duster
Re: Is there a PROBLEM Running 604 Aluminum Hemi on Street? [Re: HEMIFRED] #1389028
02/17/13 02:27 PM
02/17/13 02:27 PM
rowin4 Offline
rowin4  Offline
Yours might not but a 10.5 pump gas engine with a .700 cam?
Post deleted by moparts [Re: HEMIFRED] #1389029
02/17/13 02:27 PM
02/17/13 02:27 PM
Anonymous OP
Anonymous OP
Re: Is there a PROBLEM Running 604 Aluminum Hemi on Street? #1389030
02/17/13 08:07 PM
02/17/13 08:07 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Puddles?
Kevin
Re: Is there a PROBLEM Running 604 Aluminum Hemi on Street? [Re: Twostick] #1389031
02/17/13 08:21 PM
02/17/13 08:21 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Its very doable with the right cam...
Re: Is there a PROBLEM Running 604 Aluminum Hemi on Street? [Re: rowin4] #1389032
02/17/13 09:06 PM
02/17/13 09:06 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
you need to tailor the build to that use. no way the 1180 hp that my 604 combo has would work. a different cam and compression ratio change are the minimum needed
home of the
Re: Is there a PROBLEM Running 604 Aluminum Hemi on Street? [Re: HEMIFRED] #1389033
02/17/13 11:16 PM
02/17/13 11:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Which part of,,,,,,,,,,,,,,,,,,,,,,,,
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
