408 stroker pistons #1387090
02/13/13 09:35 PM
02/13/13 09:35 PM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
Looking at 360 magnum to 408 stroker. So far I have only found Keith Black KB356 pistons. Are there any other brands out there?
Re: 408 stroker pistons [Re: moparpollack] #1387091
02/13/13 09:39 PM
02/13/13 09:39 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
PROBE. Lite. Good quality.
Re: 408 stroker pistons [Re: moparpollack] #1387092
02/13/13 09:46 PM
02/13/13 09:46 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
BPE sells a reasonably priced forged piston . I would get in touch with him before you pull the trigger. One of the few guys that will tell you weather or not his products are a good option for you or not,and not just sell you something you don't really need. Check with him for a rotating assembly if you haven't bought anything yet.
Keith
Re: 408 stroker pistons [Re: Dunnuck Racing] #1387093
02/13/13 09:54 PM
02/13/13 09:54 PM
85086
Lil Herman
Lil Herman
85086
My buddy picked up a project with new heads, crank, rods, but no pistons. We only found the KB pistons and thought there must be someone else making pistons.
Re: 408 stroker pistons [Re: moparpollack] #1387094
02/13/13 11:34 PM
02/13/13 11:34 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Diamond and J&E makes pistons also.
Re: 408 stroker pistons [Re: Darryls-Demon] #1387095
02/14/13 12:20 AM
02/14/13 12:20 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I have forged Ross in mine. Don't know if they're still available though.
Re: 408 stroker pistons [Re: 469runner] #1387096
02/14/13 12:25 AM
02/14/13 12:25 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.kb-silvolite.com/icon/icon.ph...mp;RodLen=6.123
KB has the Icon series of forged 408 pistons also.
Tony
70 AARCuda Vitamin C
Re: 408 stroker pistons [Re: Dunnuck Racing] #1387097
02/14/13 12:40 AM
02/14/13 12:40 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Keith
x2....Just ordered a set for my 408 through Rod at BPE and can't say how pleased I am with the service. Rod is a straight shooter, and won't try to sell you what you don't need...The price for customs exactly how you want with Total Seal rings is better than prices for alot of shelf pistons.
Re: 408 stroker pistons [Re: mshred] #1387098
02/14/13 12:51 AM
02/14/13 12:51 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Use a Chevy sized rod, piston, pin (lighter, cheaper). Do some math and use a 6.125 rod and find the appropriate compression height piston for a 350 motor. You don't have to be exact because you will have to grind you crank to fit the smaller rod size (big end) but you can offset grind it at that time to get the deck height you want.
All this should be pretty easy for any decent machine shop.
Re: 408 stroker pistons [Re: TheOtherDodge] #1387099
02/14/13 01:34 AM
02/14/13 01:34 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've used Probe and KB when I put a couple together for guys.
KB is great for NA, just gotta pay attention to your ring gaps, Probe are great for spray or boost
**Photobucket sucks**
Re: 408 stroker pistons [Re: TheOtherDodge] #1387100
02/14/13 01:39 AM
02/14/13 01:39 AM
Northern Indiana
Northern Indiana
Sounds like he has the rods to fit the crankshaft he has,so that would be more money than just getting the correct pistons and a lot of unnecessary work.
Keith
Re: 408 stroker pistons [Re: moparpollack] #1387101
02/14/13 02:02 AM
02/14/13 02:02 AM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
ICON makes 3 different(20.5, 27, & 34 cc) dished pistons specifically for the magnum (1.445 C.H.). They also make a domed, a dished(20.5 cc) and a flat top in the regular LA 1.465 C.H. Just kinda depends on what heads you have and what compression you want. CNC has em pretty reasonable.
I'm watching for an LA "roller" or magnum block myself...
Jack
Re: 408 stroker pistons [Re: Jwilli500] #1387102
02/14/13 09:21 AM
02/14/13 09:21 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
No shortage of pistons for this application, so if all you found is KB's (or Icon's) you're not looking very hard.
I went with SRP's for mine. They spec'd out as light as anything else and are reasonably priced. Got mine from http://www.cnc-motorsports.com/
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 408 stroker pistons [Re: 471Magnum] #1387103
02/14/13 10:02 AM
02/14/13 10:02 AM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
SRP in mine.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: 408 stroker pistons [Re: 11secaarcuda] #1387104
02/14/13 10:13 AM
02/14/13 10:13 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
SRP here too
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: 408 stroker pistons [Re: Adobedude] #1387105
02/14/13 10:26 AM
02/14/13 10:26 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I have the Mahle Forged in mine, these are first set I've ever had by them and I am impressed with the quality of them. I'm not saying they're better than JE, Wiseco or Ross/Probe but they're certainly not any worse and the slick metric rings were included with the price. Mainly went with them since I live in NC and they have a factory near Asheville. They are the OEM for many manufactuerers, including BMW and Mercedes.
My machininst does a TON of circle track and drag motors and he swears by them, hard to beat for the $$$
WIZE
In Car:
Re: 408 stroker pistons [Re: Streetwize] #1387106
02/14/13 04:26 PM
02/14/13 04:26 PM
anaheim Ca
Bryce Mulvey Offline
anaheim Ca
I have been using CP pistons for my 408 stuff. The just fished up a piston for the Bullet line. Its a shelf piston that is 2618, and has a 1.5mm,1.5mm,3mm ring package,(steel top ring and napier sec.) These are an amazing piston for the money. They offer a flat top and a dish.
Bryce Mulvey Dr J's Performance The Home of AIRWOLF Cylinder Heads
Re: 408 stroker pistons [Re: moparpollack] #1387107
02/14/13 09:16 PM
02/14/13 09:16 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
What kind of power can be made by a 408 Magnum with a 600 lift solid flat tappet and a good set of ported heads?
And who has a good porting program for these heads?
Re: 408 stroker pistons [Re: ProSport] #1387108
02/14/13 11:09 PM
02/14/13 11:09 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Icon pistons here, no problems with them
been racing for 3 years so far and going strong in my 550+ hp barracuda IC745
Dan
Re: 408 stroker pistons [Re: Wedgeman] #1387109
02/15/13 07:31 AM
02/15/13 07:31 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Dan
What combo are you running if you dont mind?
